Small Block Edelbrock Heads
#549920
12/09/09 08:52 PM
12/09/09 08:52 PM
Posts: 52 Bakersfield, CA
MarkKirby
Bakersfield, CA
This may have been covered here previously but in your opinion who puts out the best small block Edelbrock heads, either CNC or custom ported? I have talked to Hughes, Indy, and a couple local head experts with mostly similar pricing and theories on performance.
This is for a race only stroker.
Mark & Nancy Kirby
1971 Plymouth Duster
The Grape Ape
10.20 @129mph 1.32 60'
Re: Small Block Edelbrock Heads
[Re: S/ST 3040]
#549922
12/09/09 10:12 PM
12/09/09 10:12 PM
MarkKirby
Bakersfield, CA
The specs are below....although my question is really about who is the best supplier. 416" 340 +30 4" Steel crank, H-beam Dynoed at 575hp@6500, 550lbs torque @4700 Ported J Heads flowing approximately 270 @.600" Gary Stinnet HP950 on Super Victor Cam: 627"/637" 276/281 @.050" 3300lb A-Body Low gear 904 5.13 Dana 4-link 16 x 33 GYs Stock front suspension 10.40 @125.00 1.37 60' The car works well the way it is currently setup. However, I am looking to push it over 600hp to gain mph when running Super Street and a couple tenths padding on a 10.60 index.
Mark & Nancy Kirby
The Grape Ape
[Re: MarkKirby]
#549923
12/09/09 11:17 PM
12/09/09 11:17 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
given your location, I'd talk to board member OU812, Brian at IMM.
other good small block porters: Jeff at Modern Cyl, and Ryan J at Shady Dell Speed Shop
[Re: DaKuda]
#549925
12/10/09 12:01 AM
12/10/09 12:01 AM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Lighten the car. There's no way that duster should weight 3300# unless your 400#.
[Re: patrick]
#549926
12/10/09 12:02 AM
12/10/09 12:02 AM
MarkKirby
Bakersfield, CA
Brian at IMM is an absolute genius when it comes to small blocks. I have talked to Indy about the IndyBrocks but at close to $4grand I don't see the value.
I don't need to go the full blown Indy route because I don't need to pickup 100hp....perhaps just half of that. However, although the Eddies will give me less HP gain they are certainly not HALF the cost of the Indy kit. And as far as Shady Dell is concerned...I just can't get him on the phone in spite of numerous tries.
Mark & Nancy Kirby
The Grape Ape
[Re: MarkKirby]
#549928
12/10/09 12:17 AM
12/10/09 12:17 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
Mark..
the Indybrocks are an edelbrock head that has the intake pushrod offsetted aka TA/W2 head. He is not talking about the Indy 360-1 heads, just an indy modified eddy head.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: MarkKirby]
#549930
12/10/09 12:58 AM
12/10/09 12:58 AM
Posts: 2,637 Western Michigan
68Fastback
Western Michigan
416" 340 +30 4" Steel crank, H-beam Dynoed at [Email]575hp@6500[/Email], 550lbs torque @4700 Ported J Heads flowing approximately 270 @.600" Gary Stinnet HP950 on Super Victor Cam: 627"/637" 276/281 @.050" 3300lb A-Body Low gear 904 5.13 Dana 4-link 16 x 33 GYs Stock front suspension 10.40 @125.00 1.37 60'
I have seen your car run, you have done alot of tricks to it no matter how much it weighs. Can you tell me the front to rear bias. And you can't go wrong with either Brian or Ryan, I have seen first hand from both guys 60HP gains in just their head porting, no other changes. of course you will save some freight and travel time getting them to mad man Brian but both guys even help each other out on both coasts. Good guys in my book. Good luck.
[Re: Dunnuck Racing]
#549933
12/10/09 12:13 PM
12/10/09 12:13 PM
Posts: 11,720 Portage,michigan
B3422W5
Portage,michigan
based on your current performance,( heads you have already) i would expect a set of well done eddie heads to be 2.5- to 3 tenths better than what you have currently. Not to mention a pretty decent weight savings, that you can factor in as well. knowing what i know now, and people i have talked to over the past few years, i would recommend the hughes head and the full cnc porting they offer. you are just going to have more uniformity cylinder to cylinder over hand porting, and hughes's cnc program is on the agressive side as well, they produce a nice head, a local friend just ordered a set for his 408 ...i dont see any reason whatsoever you shouldnt pick up at LEAST 40 horsepower over what you currently have, if not a little more.
there are other heads that obviously will offer a bigger gain( indy/w5, etc) but if your goals are as you stated above, the cnc eddie heads from Hughes are, IMO, easily capable of the upgrade in performance to suit your requirements. they do a lot of work with iron heads as well, give them a call and ask their opinion of a max set of eddies compared to your j heads.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
