Tunnel Ram for 440 #549656
12/09/09 11:51 AM
12/09/09 11:51 AM
...gently down the stream
LAR_414 Offline OP
LAR_414  Offline OP
Any measurments on Tunnel Rams for a RB motor? Want to find out how tall (six pack hood clearance on 69 Road Runner) they are. Any help is good....thanks
Re: Tunnel Ram for 440 [Re: LAR_414] #549657
12/09/09 03:50 PM
12/09/09 03:50 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I doubt a stock six pack scoop will clear.
Re: Tunnel Ram for 440 [Re: Dodgem] #549658
12/09/09 04:33 PM
12/09/09 04:33 PM
Mo.
supercomp Offline
supercomp  Offline
Mo.
I don't either. Here's a pic.
Re: Tunnel Ram for 440 [Re: supercomp] #549659
12/09/09 06:54 PM
12/09/09 06:54 PM
west palm beach, florida
modelmakerinc Offline
well figure at least 75% of the carb will be above a flat hood line so even with a tall sixpack scoop the carbs will still stick out.
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Re: Tunnel Ram for 440 [Re: modelmakerinc] #549660
12/09/09 10:33 PM
12/09/09 10:33 PM
Saskatchewan, Canada
barracudabob Offline
I just went out and measured mine...Weiand 5987 tunnel ram with two 750 Proform's mounted sideways, with a one inch spacer, it is fourteen inches from the valley pan to the top of the carb where the air cleaner would mount. Hope this helps, Bob
Re: Tunnel Ram for 440 [Re: LAR_414] #549661
12/09/09 10:38 PM
12/09/09 10:38 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Talk to Mike steel, OhioGTX. He runs a 68 or 69 GTX with tunnel ram and 6pak hood.
Re: Tunnel Ram for 440 [Re: ProSport] #549662
12/10/09 02:25 AM
12/10/09 02:25 AM
Hinterland SE Qld Aust
SG duster Offline
SG duster  Offline
My M1 ram fits under my duster hoog "just" with 660 center suirters, no roon for air cleaners though... as I said... "just"
Re: Tunnel Ram for 440 [Re: ProSport] #549663
12/10/09 07:49 AM
12/10/09 07:49 AM
N.E. Ohio
OhioGTX Offline
OhioGTX  Offline
N.E. Ohio
I am running an M1 TR with Victor heads/RB in a 68 GTX and using a 6 Pack hood scoop, it is a tight fit at best. I also ran this combo with EBrock RPM heads. The fit was much better with the RPM heads. The Victor head raises the intake just under an inch which makes the rear carb clearance very very tight.
Airflow into the carbs is far from optimal. If I continue to run the TR next year I would like to try some different scoop configurations and see if this is a true statement.
Glad to get you some measurements when I can get back to the garage.
I would also note that an Indy-TR/RB combo would not fit and a Wieand TR/RB combo will not fit. Either of these on a low-deck has a chance but not on an RB.
68 GTX, 9.38 at 144, Best Machine 540..
Re: Tunnel Ram for 440 [Re: OhioGTX] #549664
12/10/09 10:56 AM
12/10/09 10:56 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
The Mopar M1 tunnel ram is not as tall as the Weiand.
Keep old mopars alive.
Re: Tunnel Ram for 440 [Re: OhioGTX] #549665
12/10/09 11:15 AM
12/10/09 11:15 AM
ill
dennismopar73 Offline
ill
i would like to find a M 1 tunnel ram
anyone know where a good one is that is uncut??
Re: Tunnel Ram for 440 [Re: dennismopar73] #549666
12/11/09 05:09 PM
12/11/09 05:09 PM
Cincinnati OH
Bishop Offline
Bishop  Offline
Cincinnati OH
This is a M1 tunnel ram for a RB 9" tall going on my Jetboat
Re: Tunnel Ram for 440 [Re: Bishop] #549667
12/11/09 05:36 PM
12/11/09 05:36 PM
North Eastern New York State
montessa Offline
montessa  Offline
I, like Ohio GTX ran a M-1 tunnel ram on a B1/BS headed 528 in my 68' Charger. I ran two 750 Holleys under a six pack hood. As with Ohio, I had about 2 inches of clearance between the top of the carbs and the bottom of the hood. I also sealed the carbs from the engine with a fabricated drop base with no air cleaner. Not the ideal setup but it seemed to work all right.
Re: Tunnel Ram for 440 [Re: montessa] #549668
12/11/09 06:14 PM
12/11/09 06:14 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
here is a pic of the m1 tunnel ram on my 1973 440 dart. mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: Tunnel Ram for 440 [Re: mopar65] #549669
12/11/09 06:30 PM
12/11/09 06:30 PM
mopar65 Offline
mopar65  Offline
here is a pic on the same one on my old 65 plymouth.but to use it on the 65 i had to run a 5 inch tall max wedge scoop. Mopar65
Re: Tunnel Ram for 440 [Re: mopar65] #549670
12/11/09 11:36 PM
12/11/09 11:36 PM
Canada
CrAzYMoPaRGuY Offline
Canada
I liked my M1 intake!
CrAzYMoPaRGuY
Re: Tunnel Ram for 440 [Re: LAR_414] #549671
12/11/09 11:38 PM
12/11/09 11:38 PM
Canada
Canada
My work truck had a Weiand tunnel ram 6 pack intake that was converted to 2x4bbl, it fit under the hood with the air cleaners and all....
CrAzYMoPaRGuY
Re: Tunnel Ram for 440 [Re: CrAzYMoPaRGuY] #549672
12/11/09 11:41 PM
12/11/09 11:41 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
And if any one is looking there is a M1 TR just listed in the Race parts section of the swap area...
Re: Tunnel Ram for 440 [Re: 1_WILD_RT] #549673
12/12/09 07:59 AM
12/12/09 07:59 AM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
This is a shot of the hood that was on when Bobby was running the tunnel ram on the 65',,,
(Bobby,,were you running air cleaners ?,,,i see the rods in the carbs,,? )
one of these days,,,the 65' is going to get a NSS set up with a INDY bathtub and dual carbs....
