Who Sells the Correct Wire for a 440-6pak Solenoid ??? #549352
12/08/09 11:32 PM
12/08/09 11:32 PM
Renton, Wa.
Classof70Chally Offline OP
super gas
super gas
Renton, Wa.
Looking for a vendor or member that sells the correct wire that connects to the idle solenoid on a 70 440 6 pack motor. Thanks
Re: Who Sells the Correct Wire for a 440-6pak Solenoid ??? [Re: Classof70Chally] #549353
12/08/09 11:46 PM
12/08/09 11:46 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Isn't it part of the engine wiring harness?
Re: Who Sells the Correct Wire for a 440-6pak Solenoid ??? [Re: Snoopy] #549354
12/08/09 11:53 PM
12/08/09 11:53 PM
Renton, Wa.
super gas
super gas
Renton, Wa.
I'm sure it is but I seem to remember seeing one that had a disconnect at each end ie it wasn't one piece from the alternator. Not sure though. If it is one piece I guess I'll have to fake it and splice one in.
Re: Who Sells the Correct Wire for a 440-6pak Solenoid ??? [Re: Classof70Chally] #549355
12/09/09 08:00 AM
12/09/09 08:00 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Re: Who Sells the Correct Wire for a 440-6pak Solenoid ??? [Re: 6PakBee] #549356
12/09/09 08:34 AM
12/09/09 08:34 AM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
He's asking about a 6-pak engine, that diagram is for a 12-pak engine.
Parts I seek: driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set 16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better. 69-73 C-body caliper brackets and/or splashields Send a PM.
Re: Who Sells the Correct Wire for a 440-6pak Solenoid ??? [Re: Fury Fan] #549357
12/09/09 09:44 AM
12/09/09 09:44 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
69 1/2 6pk wire is seperate,70/70 is part of harness.
Re: Who Sells the Correct Wire for a 440-6pak Solenoid ??? [Re: 62maxwgn] #549358
12/09/09 03:50 PM
12/09/09 03:50 PM
Snoopy Offline
Snoopy  Offline
Here is a 70 Hemi engine harness. It shows how the solenoid wire is connected to the alternator field wire, brown & blue wires. These would be blue & blue on a 440-6.
Re: Who Sells the Correct Wire for a 440-6pak Solenoid ??? [Re: Snoopy] #549359
12/09/09 09:16 PM
12/09/09 09:16 PM
Renton, Wa.
super gas
super gas
Renton, Wa.
Thanks to everyone for the pics and info. I guess what made me think there was a serparate or "jumper" wire was that on my car's wiring harness installed by the guy I bought the car from, there is a open blue wire that comes out of the harness near the coil on the pass side of the intake. It has a round, rubber covered female plug on it and it is hot with the ignition on. I suppose I could use it but I think I will splice/build a correct looking one as per the pic.
Re: Who Sells the Correct Wire for a 440-6pak Solenoid ??? [Re: Classof70Chally] #549360
12/10/09 12:55 PM
12/10/09 12:55 PM
Renton, Wa.
super gas
super gas
Renton, Wa.
Well, upon further inspection and testing it appears that I have a 69 1/2 engine harness on my vert. The open, round female connector laying on the pass side of the intake (18ga dkblue) is in fact the dbl wire coming off the double wire field terminal of the alternator. So I guess I'll go with that. Is there someone that sells the wire that connects that part to the solenoid? Thanks.
Re: Who Sells the Correct Wire for a 440-6pak Solenoid ??? [Re: Classof70Chally] #549361
12/10/09 01:23 PM
12/10/09 01:23 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
You could try Bill Evans for small wiring needs, he's helped me on some stuff. 814-864-2622
Re: Who Sells the Correct Wire for a 440-6pak Solenoid ??? [Re: ScottSmith_Harms] #549362
12/11/09 09:42 AM
12/11/09 09:42 AM
Renton, Wa.
super gas
super gas
Renton, Wa.
Thanks Scott, I forgot about him. I'll give him a call. Hows the "snow level" over there?
Re: Who Sells the Correct Wire for a 440-6pak Solenoid ??? [Re: Classof70Chally] #549363
12/11/09 11:09 AM
12/11/09 11:09 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
If you have a blue wire from the alternator,it is not a 69 1/2 harness.69 is two wire alternator,black battery,green field.Also 69 1/2 solenoid wire (blue) is seperate wire from piggy back terminal on ballast resistor to the solenoid.I'd be curious as to why your blue wire has a round terminal.As for the two blue for the 70 alternator wiring,one goes to the ballast resistor,the other to tne regulator.Other than the coil,most all wires are push on spade connectors including the solenoid.
Re: Who Sells the Correct Wire for a 440-6pak Solenoid ??? [Re: 62maxwgn] #549364
12/11/09 02:41 PM
12/11/09 02:41 PM
Snoopy Offline
Snoopy  Offline
This isn't a very good picture, but it's free.
It looks like there is a separate wire for the idle solenoid. Insulated male bullet connector on the alternator end and a 90 deg. insulated female spade connector on the solenoid end.
Re: Who Sells the Correct Wire for a 440-6pak Solenoid ??? [Re: Snoopy] #549365
12/11/09 05:01 PM
12/11/09 05:01 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
69 1/2 solenoid wire compliments of another member.
Re: Who Sells the Correct Wire for a 440-6pak Solenoid ??? [Re: 6PakBee] #549366
12/11/09 05:03 PM
12/11/09 05:03 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
69 1/2 coil wire, compliments of another member.
Re: Who Sells the Correct Wire for a 440-6pak Solenoid ??? [Re: Snoopy] #549367
12/11/09 05:10 PM
12/11/09 05:10 PM
Renton, Wa.
super gas
super gas
Renton, Wa.
That looks like the ends and positioning I have. The other two wire pics shown don't match the bullet end. I don't know if my harness has someones interpetation of what it should be or if it is 'correct'. I might just buy the proper ends for my set up and build a wire. Thanks for the pics.
Re: Who Sells the Correct Wire for a 440-6pak Solenoid ??? [Re: Classof70Chally] #549368
12/11/09 10:15 PM
12/11/09 10:15 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
This isn't that difficult. The 69 1/2 cars used the standard harness with the coil wire taped into the harness. The new coil wire is connected like so into the ballast resistor. (photo from a lift off hood playground member)
Re: Who Sells the Correct Wire for a 440-6pak Solenoid ??? [Re: 6PakBee] #549369
12/11/09 10:17 PM
12/11/09 10:17 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Solenoid wire is connected like so (photo also from a lift off hood playground member).
Re: Who Sells the Correct Wire for a 440-6pak Solenoid ??? [Re: 6PakBee] #549370
12/11/09 10:47 PM
12/11/09 10:47 PM
Snoopy Offline
Snoopy  Offline
He needs one for a 70 440-6.
Re: Who Sells the Correct Wire for a 440-6pak Solenoid ??? [Re: Snoopy] #549371
12/12/09 07:46 AM
12/12/09 07:46 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I am an idiot. Sorry about that.
