Re: challenger window nut/clip
[Re: joelson6]
#549162
12/08/09 11:21 PM
12/08/09 11:21 PM
Posts: 27,480 So Cal
autoxcuda
So Cal
when i bought a window hardware rebuild kit for my challenger i was told that everything to rebuild the sliders is in there----------yea, right....
What's wrong with the rebuild kit?
The clip is a non wear item. No reason it should be in a rebuild kit.
[Re: joelson6]
#549165
12/09/09 10:17 PM
12/09/09 10:17 PM
Posts: 1,822 Colorado
denfireguy
Colorado
Ten years ago I could not find them anywhere. Glass shops around here were a dead end. I made my own with spring steel from a retainer for hanging cable trays in TV stations and such. Drilled a hole in it smaller than the screw then dimpled it with a center punch to provide more grab. It is still in there. Still would highly recommend the real part for peace of mind. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
