Re: 440 Build up for max TQ Help.
[Re: Milan]
#54839
03/14/08 05:58 AM
03/14/08 05:58 AM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
Well I just got my wife's 440 back from the machine shop and its time to start picking the other parts for the engine and I need some opinions. My Goal is to use the stock 902 heads and buld as much power as I can so that her 70 Challenger stands a chance against my LS6 Chevelle. I need to stay with a 92-93 octane premium fuel. Can you help me choose some Hyperutectic pistons and a hydraulic cam? I am using stock cast crank and rods.
Thanks Milan
Milan, i would use the KB quench dome pistons & a cam in the mid-high 230s split on dur. @ 50 with a lift around 500/510 on a 110 (i would look at the VooDoo cams), either a SD or RPM (prefer the SD) with an 850 & 1.7/8 headers, Ron (383man) has a nice set-up & its in the mid 11s with iron heads, he runs on pump gas.
Now don't sink too much in those iron heads, if they need a total going through, you may just want to get some 440Source Stealths with a FT piston, but if the 902s are in good shape & are ready to run, for an added .2 & 2-3 mph, a nice bowl blend & back-cut on the valves should do it, this stuff plus a moderate stall & gears should no doubt spank that LS6 ![](/ubbthreads/images/graemlins/beer.gif)
[Re: Milan]
#54841
03/15/08 02:55 AM
03/15/08 02:55 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
Joe thank you for the kind words about my 63. ![](/ubbthreads/images/graemlins/wave.gif) Yes I use open chamber stock type iron 906 heads. I also use the KB quench pad pistons to get about .042 quench and it runs fine on 92 pump. I use the solid MP .557 cam that had 296 advertised duration and it works great on my 63's 440 for the street. I will say this that it is alot of work using the quench pad pistons and open chamber heads. I had to measure each head chamber depth and each piston pad height. Then I had to do some grining on the chambers to get the quench even on all cylinders. I only used that setup because I got the parts real cheap from my brother. If you decide to use the Stealth (440Source) aluminum closed chamber heads it would be much easier to build a flattop piston zero deck eng and then use Felpro .039 head gaskets with the closed chamber heads. But that said I used the KB quench pad pistons and I spent the time to get even quench and the car runs as good or better then I wanted and I think it still has more in it as I have done no serious tuning yet. At 3700 lbs with a basically stock bottom end 440 and factory iron heads it has run 11.50's @ 116 so far and I drive it to the track as it is my street car driver. I was looking for mid to high 11's so I hit my goal with no trouble. If you have not bought pistons I would think real hard about using the $899. closed chamber heads and get a flattop piston that will sit at zero deck. It will be easier to build. Good luck , Ron
[Re: topside]
#54845
03/15/08 12:52 PM
03/15/08 12:52 PM
DaytonaTurbo
Manitoba, Canada
I would recommend getting the pistons first and then boring the block to size.
there. Different styles of pistons require different amounts of clearance. Forged, hyper, their requirements are not all the same. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: Milan]
#54848
03/16/08 10:22 AM
03/16/08 10:22 AM
Posts: 4,794 Holland MI Ottawa
2boltmain
Holland MI Ottawa
In the 80s I owned 2 challengers where we took good running 375hp 440 magnums and did rings, bearings, gaskets and oil pump. (These engines were around in good condition then) Heads were left alone if they looked fine (usually 906) but added the old stand byes- Torker intake, Holley 750 carb, blackjack headers, cam- I ran the mopar 484 purpeshaft, shift improver kit and a sure grip rearend. With a 3:23 gear the one ran high 13s. Even with OEM heads it asy to make a 440 run provided the compression is there. Years ago a mopar mag built a 440 to stock 375 hp specs. THEIR dyno pulled around 360 hp. Then they added an M1 single plane, Holley mechanical secondary carb, 509 cam and headers. They then pulled 425 hp. Heads were restored 906s but not bowl ported or dressed. 509 cam has lots of duration but the point is how well the motor responded.
Keep old mopars alive.
[Re: 2boltmain]
#54849
03/16/08 10:57 AM
03/16/08 10:57 AM
Posts: 549 Chicagoland
chargerron69
Chicagoland
i went 11.80s with a stock unported 452 head in 67 coronet with a comp xtreme energy XE292 cam with about 9-9.5 compression with trw pistons in it. i was really impressed by it. and the the motor has a really nice sound at idle. ![](/ubbthreads/images/graemlins/Twocents.gif) Ron
67 Coronet 383 hogged out 906's 727 430 dana best 10.48 @126.80 1.47 60 on fogger
same car pump gas 605 wedge 9.98 @ 138.42 1.50 60 on wore out 9 inch radial slick ss springs and frame connectors its got more in it!!!
72 Newport 2 door 400 727
85 Ram 440 4 speed O/D 3.54 dana
[Re: Milan]
#54850
01/24/09 07:29 AM
01/24/09 07:29 AM
Posts: 52 Westlake, Ohio, USA
Milan
Westlake, Ohio, USA
I was contemplating between the KB146 and KB236 any thoughts between those two pistons?
Any thoughts between these TWO?
I ordered a set of KB363 only to have summit cancell my order saying those pistons are no longer made. I have a SUMMIT-6401 Cam in the block now
Thanks Milan
[Re: Milan]
#54854
01/24/09 10:12 AM
01/24/09 10:12 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Thanks Milan
I had that in my 67 coronet. Good cam. I liked it much better than the 484 that was in it. It had a much beeter power band and great drib=vability. My 440 was mostly stock 9:1, stock 906 heads in a 3900lbs car and it ran 12.90's. With more compression and better heads I could have ran 12.50's
[Re: blownzoom440]
#54856
01/24/09 10:57 AM
01/24/09 10:57 AM
Posts: 4,961 WI
Dcuda69
WI
Wow,this thread started in Mar.08 about torque,then to be able to run with an LS6 Chevelle and do it on a budget? I think the LS6 made 450hp and 500ft lb in stock form. Didn't the LS6 have some good flowing heads and a solid cam in them? I think it will take more than TQ to make them run together. A good torquey 440 will run out of steam as that LS6 starts working. 10.5:1 comp. ratio,some good heads,a modern cam(maybe solid)exhaust,converter,gears,etc.If you want to run with that LS6,you'll have to build it w/similar components. ![](/ubbthreads/images/graemlins/Twocents.gif) P.S Ron's(383 Man) is your guideline,well thought out and executed combo! ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Dcuda69]
#54857
01/24/09 11:05 AM
01/24/09 11:05 AM
Posts: 8,647 ELYRIA,OH
blownzoom440
ELYRIA,OH
TQ over a wide rpm band. ![](/ubbthreads/images/graemlins/thumbs.gif)
