Re: lucas oil treatment? any one else [Re: therocks] #548297
12/08/09 11:43 AM
12/08/09 11:43 AM
Mesa , Az
Jambbii Offline
Jambbii  Offline
Mesa , Az
Ok , the stuff is sticky, but wouldn't thicker oil do somewhat the same thing as lucas? I have never had any issues with normal oil. Yeah I have had lifter ticks and ran thicker oil and that magically fixed it or was a temp. bandaid. Sorry but I just still don't believe in oil additives.
70 Challenger
1960 Town Wagon P Pump 24v cummins project
06 Mega 3500 Drw 2wd
12 Durango R/T
18 Power Wagon
67 A100
Re: lucas oil treatment? any one else [Re: Jambbii] #548298
12/08/09 12:19 PM
12/08/09 12:19 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
Accually regular oil will not stick even heavier oils, they warm up and wick down back to the pan.
Lucas bad, Bradd Penn Good!!!
Re: lucas oil treatment? any one else [Re: MMiller] #548299
12/08/09 02:39 PM
12/08/09 02:39 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I ran a little in my Getrag 5 speed behind my Cummins. I changed the oil, added the Lucas Oil treatment, to the specified oil for the trans. After that the trans shifted horribly, and was far more noisy. I ran it a while like that and it did not get better. I drained out the oil and as much Lucas as I could get out of it. I then refilled it with specified oil and ran the trans went back to shifting nice, and no more noise. Ran it a long time with lots of heavy loads, lots of tire chirping, speed shifts and such before the output shaft bearing finally became pitted and noisy.
I've since rebuilt it with new bearings, and filled it with synthetic oil, and had great service.
No Lucas for me.....
Michael
I did the same with my Old Toyota 4x4. While it did reduce some noise it was a bear to shift when cold. In the winter I would put the transfercase in nuetral and leave the trans in gear when I warmed it up. That way It was tollerable to shift it lol.
68 Barracuda Formula S 340
Re: lucas oil treatment? any one else [Re: Bad340fish] #548300
12/08/09 03:07 PM
12/08/09 03:07 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I don't use their oil treatment or much of anything else they sell but have tried their assembly lube on a couple motors lately, and it seems pretty good, I sort of like it. It seems to work about as well as the old standby Clevite bearing guard, and seems to stick/cling to parts maybe a little bit more.
Lucas Oil's Assembly Lube is designed to be an initial lubricant to metal surfaces. Apply to critical engine surfaces before assembly in order to prevent metal to metal contact, upon startup, before adequate lubrication is supplied. Will mix with any oil and will not plug filters. This product clings to all surfaces and is an excellent rust inhibitor, allowing long term storage for all parts. It is useful wherever tension or torque is applied. Contains Zinc, Moly, and other extreme pressure additives. Perfect for engine building or any assembly.
http://lucasoil.hodgsoncorp.com/catalog/...amp;x=5&y=6
Re: lucas oil treatment? any one else [Re: ZIPPY] #548301
12/08/09 07:44 PM
12/08/09 07:44 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
I've used Lucas transmission conditioner to fix busted automatic transmissions. It's like a miracle, brings dead slushboxes back to life.
Re: lucas oil treatment? any one else [Re: Hemi_Joel] #548302
12/08/09 07:58 PM
12/08/09 07:58 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
Joel, I've also heard Lucas Gear Rejuvenator restores the nylon gears on your stock cam timinggear...
Re: lucas oil treatment? any one else [Re: ben1692] #548303
12/08/09 09:03 PM
12/08/09 09:03 PM
madison, ohio
modified1090 Offline
madison, ohio
i think that i have something from lucas in every fluid in my car. even the fuel tank. i think i am going to switch the fuel lube next year though, too sticky and doesn't mix well with the e85
Re: lucas oil treatment? any one else [Re: MMiller] #548304
12/08/09 10:38 PM
12/08/09 10:38 PM
Rather be in Fallon, Nevada
RussW Offline
super gas
RussW  Offline
super gas
Michael
I run RedLine MT90 and MTL 50-50 mix in my NV4500 and ran the same in my previous Cummins, 93 W350
