Re: 1969 440 oil pump drive
[Re: moparrookie]
#548186
12/07/09 02:09 PM
12/07/09 02:09 PM
Posts: 1,051 Slidell, La.
doctor_mopar
Slidell, La.
If the other methods have failed you. Take the oil pump off , and you can tap the shaft up and out from that end.
------------------------ It doesn't matter what you do.........As long as you look good doing it !
[Re: stumpy]
#548188
12/07/09 03:29 PM
12/07/09 03:29 PM
Posts: 9,336 South-Central (Sebring), FL
Commando1
I'm going to show you the neatest little tool you'll ever have in your toolbox. Absolutely invaluable if the intake manifold is still on and you want to extract or install the distributer gear properly aligned. You'll need: Aprox. 18" of PVC pipe (1) PVC pipe union (1) 8" ty-wrap Make a small chamfer at one end of the pipe Lay the ty-wrap onto the chamfer Install the union Insert the dizzy gear into the union. It's a 'jam' fit. Align the slot on the dizzy with the ty-wrap. The best distributer gear installation (and removal) tool in the world and it cost next to nothing.
[Re: Commando1]
#548189
12/07/09 04:30 PM
12/07/09 04:30 PM
Posts: 4,861 Riverside, Ca
R70RUNNER
Riverside, Ca
Stanley, Love homebuilt specialty tools that cost
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
[Re: moparrookie]
#548191
12/07/09 04:59 PM
12/07/09 04:59 PM
Posts: 75,094 A Banana Republic near you.
JohnRR
It is a new bushing and I tried it prior to installing it and it slide over the shaft fine. I installed the bushing then greased the shaft and pushed down as far as I could reach and then lightly tapped the gear home. The book I have says the notch on the top of the gear needs to be in the same line as the crank, it is now one gear slot toward the top of the engine. Are you saying it is ok to leave it.
Here is your first PROBLEM .. the bushing needs to be SIZED after install , the correct installation tool does this , the fact that you had to DRIVE the gear in tells me you didn't have the correct tool .
Remove the the oilpump and use a wood or alum dowel and drive it back out , if you don't the bushing will more than likely sieze on the shaft and spin in the block potentially wrecking the block ...
I have been able to always remove the oil pump drive with needle nose pliers ,I have even had luck spinning it back UP wit ha long screwdriver on occasion . The drive ALWAYS just falls into place , if you have to tap it in you have a PROBLEM ...
[Re: moparrookie]
#548198
12/07/09 08:58 PM
12/07/09 08:58 PM
JohnRR
no sign of brass shavings and what I mean is the shaft drops into place until I get to the gears and have not tried to go any further at this point until I got the ok from you guys
Did it drop in like that the first time or did you have to drive it all the way in ? it should just go right in , if you have to tap it all all it's still too tight .
Is the timing cover on the engine right now ? If not I would pull out the cam and make sure it drops all the way in and FREELY spins .
[Re: moparrookie]
#548200
12/08/09 12:57 PM
12/08/09 12:57 PM
JohnRR
it drops in all the way to the gear
But it needs to drop in all the way to it's final seated position.
I don't have one handy but I'm pretty sure the part that rides inside the bushing is a little bigger than the rest of the shaft length ?
