Page 2 of 3 1 2 3
Re: welding race cars [Re: Sixpak] #547956
12/07/09 06:40 PM
12/07/09 06:40 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Maybe one of the pro-welders out there can answer this: I always thought the reason that chrome moly could not be migged because mig uses a 'mild steel' rod and/or w/copper coating and that the mixing/welding together of mild steel or other metals not similar to chrome moly causes weld embrittlement. So why not MIG with chrome moly wire instead?
Their main concern is that you can over heat the
tubing with a mig, the tig concentrates the heat more
Re: welding race cars [Re: joshking440] #547957
12/07/09 06:54 PM
12/07/09 06:54 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
i wouldn't say tig is easier but i doubt there's any argument it's the best. i have a syncrowave 250 with a water cooled torch and unfortunately it's a lot better welder than i am. i really wish i could weld better but i don't do it enough to remain proficient. i've been wanting to pick up some classes even offered a very skilled welder money to spend time with me but neither ever came about. i do agree if someone said i could only have one welding skill it would be tig hands down.
might be some interesting info here web page
Re: welding race cars [Re: jamesc] #547958
12/07/09 08:41 PM
12/07/09 08:41 PM
gregsdart Offline
gregsdart  Offline
I am fabbing up some upper control arms out of moly tube. Would it be safe to mig weld the tube ends and ball joint part on with mild steel wire?
Re: welding race cars [Re: gregsdart] #547959
12/07/09 09:03 PM
12/07/09 09:03 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Sure, you can use a ER70s-6 wire for that... be sure
to drill 2 holes in the tube (one on each side) so
when you insert the threaded insert you can do a puddle
weld to it(hope you see what I'm saying)
Re: welding race cars [Re: MR_P_BODY] #547960
12/07/09 10:20 PM
12/07/09 10:20 PM
corpus christi tex
Cheatham Offline
Cheatham  Offline
corpus christi tex
I was in your situation so i bought a Miller 180 it was a little more pricey than the others but it has more than enough power for car suspension welding etc etc. i paid about 800.00 and a friend gave me a short bottle (argon) now i need a auto darkening helmet, christmas list lol
Re: welding race cars [Re: Cheatham] #547961
12/07/09 10:39 PM
12/07/09 10:39 PM
Btween a rock and a hard place
moparlulu Offline
moparlulu  Offline
A miller 180 would be the smallest welder I'd be looking at. It can also be outfitted with a spool gun Which if you have the funds is worth it, as said you can weld alum.With it. I use mine for stainless and aluminum I have a miller 252 with the spool gun and a 250 synhrowave tig. I use the snot out of them all. Only down side is my bottle rent is more than I'd like.
Re: welding race cars [Re: moparlulu] #547962
12/07/09 11:05 PM
12/07/09 11:05 PM
MR_P_BODY Offline
MR_P_BODY  Offline
What do you give for a bottle and what size...whats
the price for argon
Re: welding race cars [Re: MR_P_BODY] #547963
12/07/09 11:11 PM
12/07/09 11:11 PM
corpus christi tex
Cheatham Offline
Cheatham  Offline
corpus christi tex
the price for argon
the ones i priced was a 4 foot tall bottle i dont know how its classified but its about 4ft tall and to purchase was going to be 180.00. I was lucky and a friend had one sitting around and let me have it refills are about 24.00.
Re: welding race cars [Re: MR_P_BODY] #547964
12/07/09 11:11 PM
12/07/09 11:11 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
the price for argon
much better to just buy the bottles the last time I swapped my 135cf of 75/25 mix it was around 40.00
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: welding race cars [Re: MR_P_BODY] #547965
12/07/09 11:25 PM
12/07/09 11:25 PM
moparlulu Offline
moparlulu  Offline
Mr P, I rent 4 bottles 1 of each of these sizes K, Q, S, WQ rent is $36 a month Plus I own 3 s's and a q. For the big bottles of 100% argon it cost $78 to fill. For our "Norgas" its 75%-23% and it has a touch of oxygen and helium runs $63 for the big bottle. Oxygen in a q runs about $45 and the acetylene is about $38 to fill.
Re: welding race cars [Re: moparlulu] #547966
12/07/09 11:43 PM
12/07/09 11:43 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I bought all of my bottles... well almost all, I
got 1 330 cuft bottle from work when we changed gas
companies... anyways I gave $90 for my 120 cuft bottles
4 are my 75-25 argon/co2 and 2 are argon, my 330
is also straight argon... cost is about $18 to fill
my 120 bottles and $45 for the 330(might be a little
more now... I havent filled them for almost 8 months)
Re: welding race cars [Re: Dave Watt] #547967
12/08/09 01:14 AM
12/08/09 01:14 AM
Mobile Alabama
SB412DUSTER Offline
SB412DUSTER  Offline
Mobile Alabama
TIG welding can be extremely difficult to do if you are laying on your back under a car, you would need a thumb control because you can't be pressing the pedal while laying down.
Thats what the side of your leg is for
Re: welding race cars [Re: SB412DUSTER] #547968
12/08/09 01:15 AM
12/08/09 01:15 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
duct tape it to your foot.
Re: welding race cars [Re: SB412DUSTER] #547969
12/08/09 09:12 AM
12/08/09 09:12 AM
NW Pa.
KD800X Offline
KD800X  Offline
NW Pa.
Been there!
Re: welding race cars [Re: MR_P_BODY] #547970
12/08/09 09:37 AM
12/08/09 09:37 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
You guys are buying you're gas cheap , the last time I filled my 80 bottle with 75/25 it was $42 . When I bought my 210 I also bought the bottle, it cost the same to buy it as it would to pay two five year leases.
Re: welding race cars [Re: justinp61] #547971
12/08/09 11:22 AM
12/08/09 11:22 AM
SD800 Offline
SD800  Offline
When I took my Challeger to have it certified the first question the guy asked was what did you weld it with a 110 volt or 220 volt mig welder? We used a 220 volt and I asked why he asked, he said if we had used a 110 volt he would not certify it, got my sticker 25.4 certified!!!
You'll have plenty of time to sleep when your dead, let's go
Re: welding race cars [Re: SD800] #547972
12/08/09 11:50 AM
12/08/09 11:50 AM
Phoenix, AZ
Comp_Chassis Offline
Phoenix, AZ
If you are planning on doing a lot of fabrication I would certainly suggest going with a larger 220 volt machine. Sometimes the little 110 machines can provide the penetration on thinner items, but you will always be running the machine at its maximum and it will burn up quickly.
We repaired a car years ago that was built with a 110 welder. The welds all looked beautiful, except that the first time they let go of the trans brake the rear end spun backwards out of the car. The roll cage was also installed with the same welder. We cut one of the door bars by the floor and just popped the other weld right off the main hoop by pulling on it.
Tig machines will weld anything you will come across, but it is slow and labor intensive compared to mig welding. Not to mention, sometimes its hard enough to get a mig gun into some places on a race car, now think about getting the tig torch, your other hand and filler rod in there, your head in a position so you can see the puddle and then throw also trying to operate the foot pedal all at the same time.
As for shielding gas. Obviously with a tig you are pretty much stuck with argon. With the mig there are various mixes you can use. I have tried several of the different mixes over the years and I have always gone back to using just straight CO2. Last time I filled a large bottle it was like $25, lasts about 3-4 times longer than mix gas and Ive always been happier with the welds.
Re: welding race cars [Re: Comp_Chassis] #547973
12/08/09 12:23 PM
12/08/09 12:23 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Just go striaght to the TIG. Learn to weld with this maybe even take a night coarse at the local Tech college if need be.
I also suggest owning a Mig for little easy jobs like a lawn mower deck etc.
Get at least a 140 amp Mig
And that new Miller Diversion looks to be a nice little welder.
Re: welding race cars [Re: SD800] #547974
12/08/09 01:53 PM
12/08/09 01:53 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
I dont know who certified your car, but I know Tom Block in Michigan and he would not certify a chrome-moly anything that was not tig welded
Re: welding race cars [Re: joshking440] #547975
12/08/09 02:23 PM
12/08/09 02:23 PM
MR_P_BODY Offline
MR_P_BODY  Offline
No one should if it was moly and migged
Page 2 of 3 1 2 3
