Re: welding race cars
[Re: Sixpak]
#547956
12/07/09 06:40 PM
12/07/09 06:40 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Maybe one of the pro-welders out there can answer this: I always thought the reason that chrome moly could not be migged because mig uses a 'mild steel' rod and/or w/copper coating and that the mixing/welding together of mild steel or other metals not similar to chrome moly causes weld embrittlement. So why not MIG with chrome moly wire instead?
Their main concern is that you can over heat the tubing with a mig, the tig concentrates the heat more
[Re: gregsdart]
#547959
12/07/09 09:03 PM
12/07/09 09:03 PM
MR_P_BODY
I am fabbing up some upper control arms out of moly tube. Would it be safe to mig weld the tube ends and ball joint part on with mild steel wire?
Sure, you can use a ER70s-6 wire for that... be sure to drill 2 holes in the tube (one on each side) so when you insert the threaded insert you can do a puddle weld to it(hope you see what I'm saying)
[Re: MR_P_BODY]
#547963
12/07/09 11:11 PM
12/07/09 11:11 PM
Posts: 456 corpus christi tex
Cheatham
corpus christi tex
Only down side is my bottle rent is more than I'd like.
What do you give for a bottle and what size...whats the price for argon
the ones i priced was a 4 foot tall bottle i dont know how its classified but its about 4ft tall and to purchase was going to be 180.00. I was lucky and a friend had one sitting around and let me have it refills are about 24.00.
[Re: moparlulu]
#547966
12/07/09 11:43 PM
12/07/09 11:43 PM
MR_P_BODY
Mr P, I rent 4 bottles 1 of each of these sizes K, Q, S, WQ rent is $36 a month Plus I own 3 s's and a q. For the big bottles of 100% argon it cost $78 to fill. For our "Norgas" its 75%-23% and it has a touch of oxygen and helium runs $63 for the big bottle. Oxygen in a q runs about $45 and the acetylene is about $38 to fill.
I bought all of my bottles... well almost all, I got 1 330 cuft bottle from work when we changed gas companies... anyways I gave $90 for my 120 cuft bottles 4 are my 75-25 argon/co2 and 2 are argon, my 330 is also straight argon... cost is about $18 to fill my 120 bottles and $45 for the 330(might be a little more now... I havent filled them for almost 8 months)
[Re: Dave Watt]
#547967
12/08/09 01:14 AM
12/08/09 01:14 AM
Posts: 2,360 Mobile Alabama
SB412DUSTER
Mobile Alabama
TIG welding can be extremely difficult to do if you are laying on your back under a car, you would need a thumb control because you can't be pressing the pedal while laying down.
Thats what the side of your leg is for
[Re: SB412DUSTER]
#547968
12/08/09 01:15 AM
12/08/09 01:15 AM
Posts: 12,271 Overpriced Housing Central
RobX4406
duct tape it to your foot.
[Re: SB412DUSTER]
#547969
12/08/09 09:12 AM
12/08/09 09:12 AM
Posts: 764 NW Pa.
KD800X
NW Pa.
Been there!
[Re: MR_P_BODY]
#547970
12/08/09 09:37 AM
12/08/09 09:37 AM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
You guys are buying you're gas cheap , the last time I filled my 80 bottle with 75/25 it was $42 . When I bought my 210 I also bought the bottle, it cost the same to buy it as it would to pay two five year leases.
[Re: justinp61]
#547971
12/08/09 11:22 AM
12/08/09 11:22 AM
Posts: 388 Michigan
SD800
When I took my Challeger to have it certified the first question the guy asked was what did you weld it with a 110 volt or 220 volt mig welder? We used a 220 volt and I asked why he asked, he said if we had used a 110 volt he would not certify it, got my sticker 25.4 certified!!!
You'll have plenty of time to sleep when your dead, let's go
[Re: SD800]
#547972
12/08/09 11:50 AM
12/08/09 11:50 AM
Posts: 1,686 Phoenix, AZ
Comp_Chassis
Phoenix, AZ
If you are planning on doing a lot of fabrication I would certainly suggest going with a larger 220 volt machine. Sometimes the little 110 machines can provide the penetration on thinner items, but you will always be running the machine at its maximum and it will burn up quickly.
We repaired a car years ago that was built with a 110 welder. The welds all looked beautiful, except that the first time they let go of the trans brake the rear end spun backwards out of the car. The roll cage was also installed with the same welder. We cut one of the door bars by the floor and just popped the other weld right off the main hoop by pulling on it.
Tig machines will weld anything you will come across, but it is slow and labor intensive compared to mig welding. Not to mention, sometimes its hard enough to get a mig gun into some places on a race car, now think about getting the tig torch, your other hand and filler rod in there, your head in a position so you can see the puddle and then throw also trying to operate the foot pedal all at the same time.
As for shielding gas. Obviously with a tig you are pretty much stuck with argon. With the mig there are various mixes you can use. I have tried several of the different mixes over the years and I have always gone back to using just straight CO2. Last time I filled a large bottle it was like $25, lasts about 3-4 times longer than mix gas and Ive always been happier with the welds.
[Re: Comp_Chassis]
#547973
12/08/09 12:23 PM
12/08/09 12:23 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Just go striaght to the TIG. Learn to weld with this maybe even take a night coarse at the local Tech college if need be. I also suggest owning a Mig for little easy jobs like a lawn mower deck etc.
Get at least a 140 amp Mig And that new Miller Diversion looks to be a nice little welder.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: SD800]
#547974
12/08/09 01:53 PM
12/08/09 01:53 PM
Posts: 4,590 Indy
joshking440
Lunch is on me!
Lunch is on me!
Indy
I dont know who certified your car, but I know Tom Block in Michigan and he would not certify a chrome-moly anything that was not tig welded
[Re: joshking440]
#547975
12/08/09 02:23 PM
12/08/09 02:23 PM
MR_P_BODY
No one should if it was moly and migged
