Oil Pan with stamping "971"? #54792
03/11/08 06:37 PM
03/11/08 06:37 PM
RoadyCrazy Offline OP
I'd like to know what size/year an oil pan with the stamping "971" was used on. I have 1973 & 1974 parts books that indicate 400/440 R and W carlines had an 3614970 P/N oil pan, which is the application I'm looking at. I didn't find any 3614971 within either of those parts books or any number in the oil pan section that ended in "971".
Please help.
Re: Oil Pan with stamping "971"? [Re: RoadyCrazy] #54793
03/11/08 07:51 PM
03/11/08 07:51 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Yeah, the part number is different than the stamping number...They don't want to make it that easy to find one !!! ..I remember that from when I bought the new one from M.P....It's for a big block using the isolated K frame {73-up RR, cordoba,charger, etc...}
Re: Oil Pan with stamping "971"? [Re: screamindriver] #54794
03/11/08 08:20 PM
03/11/08 08:20 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
what he said , and FYI you can still buy that pan brand spanking new from mopar
Re: Oil Pan with stamping "971"? [Re: RoadyCrazy] #54795
03/12/08 12:08 PM
03/12/08 12:08 PM
Thanks for your help!!!!!
Re: Oil Pan with stamping "971"? [Re: RoadyCrazy] #54796
03/12/08 12:18 PM
03/12/08 12:18 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
If anyone needs a 971 pan, just order up P5007807AB.
Matching 3/8 pickup tube assy is P5007848.
Re: Oil Pan with stamping "971"? [Re: ZIPPY] #54797
03/13/08 04:10 PM
03/13/08 04:10 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Here is something funny I found, Moroso also sells the 971 pan If I had to guess, they are probably buying it from Mopar, painting it black and putting their decal on it.
What a crazy business
Re: Oil Pan with stamping "971"? [Re: ZIPPY] #54798
03/13/08 10:18 PM
03/13/08 10:18 PM
Harrisburg, Pa.
Harrisburg, Pa.
..That's wild !! ... Here's my 971 pan on the car{73RR} and a backside shot of the skid plate I fabbed up so I can jack on the K frame without the risk of customizing the front of the oil pan...I have the M.P. deep pan to go on the trans yet and hopefully the skid plate is going to do the job of running blocker...
