Your opinions Please- my motor is finally apart ! #547789
12/07/09 05:15 AM
12/07/09 05:15 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
After around 4 years I got my engine torn down tonight. Never a major problem with it--but its long overdue for inspection.
Im posting some pics I took of various parts to see what ya'll think. I dont have the crank out yet, but theres some pics of 2 of the rod journals , rod bearings , pistons , and the solid cam.
its a 493, Ross pistons, Clevites, Scott Brown solid cam, pump gas, eddy rpm heads. Never shifted the thing over 6200 .
rod
http://img.photobucket.com/albums/v225/solrizzo/rod2.jpg
rod 2
http://img.photobucket.com/albums/v225/solrizzo/rod1.jpg
piston 1
http://img.photobucket.com/albums/v225/solrizzo/piston2.jpg
piston 2
http://img.photobucket.com/albums/v225/solrizzo/piston1.jpg
cam lobes
http://img.photobucket.com/albums/v225/solrizzo/cam2.jpg
cam lobes 2
http://img.photobucket.com/albums/v225/solrizzo/cam1.jpg
crank 1
http://img.photobucket.com/albums/v225/solrizzo/crank2.jpg
crank2
http://img.photobucket.com/albums/v225/solrizzo/crank1.jpg
among other things---do those cam lobes look ok--or nice and worn ?
Obviously im putting new bearings in the ol' girl...
Re: Your opinions Please- my motor is finally apart ! [Re: 493_DART] #547790
12/07/09 06:44 AM
12/07/09 06:44 AM
that looks pretty normal. a simple freshening is obviously in order but the camshaft should be replaced IMO. i'd check the bottom of the lifters to see if they are still convex shaped. looking at the worn lobes, some of the lifters might be flat or convex now. how do the cylinder walls look? timing chain stretch? valve springs and guides???, etc. etc.
Re: Your opinions Please- my motor is finally apart ! #547791
12/07/09 07:59 AM
12/07/09 07:59 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
thanks for the reply D ,
lifters are Comp-they looked great to the eye,
cylinders have some wear--will be getting those honed and inspected for sure---with new rings of course .
the timing chain shows about 1/4" play ( pushing it in from a flat edge) . ! seems too much ?
Havent looked at the heads but they were basic ported / gone through 2 years ago. Springs are new 8005 Isky a year ago.
i didnt think that timing chain would get that loose after 3 years.....its a Comp double roller
i think my "freshen up" deal is going to get expensive...
LOG BOOK SHOWS 182 PASSES----PLUS MAYBE 30 STREET MILES !
doesnt it always happen like that ?
Re: Your opinions Please- my motor is finally apart ! [Re: 493_DART] #547792
12/07/09 09:46 PM
12/07/09 09:46 PM
NC
440Jim Offline
440Jim  Offline
NC
I find it very difficult to see issues from pictures, especially on the computer/web size. Even an untrained eye in person has a hard time seeing things unless they are very bad (or like new).
182 passes isn't a lot, but 4 years is a good time to do an inspection. I have seen better bearings, and worse in that number of runs. You need to look carefully at each one to see if any machining variations need addressing.
Like you said, the bearings and timing chain obviously should not be reused. The cam is a tougher call, from eye ball pictures on the web.
Re: Your opinions Please- my motor is finally apart ! #547793
12/21/09 08:33 PM
12/21/09 08:33 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
i did look at the lifters again today. Some look pretty flat , some ARE convex ...
There is some scuffing at the bottom of some of the bores and the piston skirts .
What are the causes of the scuffing - too little piston to bore clearance?
The pistons were new Ross with file fit rings , 4.350 bore
Re: Your opinions Please- my motor is finally apart ! [Re: 493_DART] #547794
12/21/09 08:39 PM
12/21/09 08:39 PM
okla.
sam64 Offline
sam64  Offline
okla.
could be pieces of the lifters that are going?i had cam loose 4 lobes and lifters,trashed the skirts on bores only 2 passes.
Re: Your opinions Please- my motor is finally apart ! [Re: 493_DART] #547795
12/22/09 01:34 AM
12/22/09 01:34 AM
The piston bottoms look like they are coming out of the bottom of the cylinders,yes? If so mine look like that also and they measure good, check yours to see(if you have the original specs on them) if they are worn or not. I have found(and have quit using them) that the Ross piston skirts seem to be very delicate and show damage(scratching) when they are not worn I have now switch to Diamond Pistons for that very reason
Re: Your opinions Please- my motor is finally apart ! [Re: 493_DART] #547796
12/22/09 01:34 AM
12/22/09 01:34 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Looks like normal wear to me as I worked for a local builder and we freshened roundy-round motors that looked similar after a season of racing. I agree about a new cam/lifters(roller if you can) would be nice and as an example, my car has roughly as many passes and a few thousand street miles and ran it`s quickest pass earlier this year. Why did u tear it down anyways? Just curious. I hope to freshen mine soon unless it sells. Good luck w/it.
Re: Your opinions Please- my motor is finally apart ! [Re: Thumperdart] #547797
12/22/09 01:47 AM
12/22/09 01:47 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Got a set of calipers? Measure the lobes see if you read a diff..Its hard to tell from the pics, but that one lobe does look like it has some wear...The pistons, and bearings are pretty much normal wear..
Re: Your opinions Please- my motor is finally apart ! [Re: Bob_Coomer] #547798
12/22/09 02:19 AM
12/22/09 02:19 AM
tboomer Online work
tboomer  Online Work
Kevin...Gonna have Hollywood or Steve look at it?
Re: Your opinions Please- my motor is finally apart ! [Re: tboomer] #547799
12/22/09 04:22 AM
12/22/09 04:22 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
ok...thanks guys.
Thumper - i tore it down just to see how things were looking inside --it was due.I dont see any major issues
Cab-- so thats a normal thing with Ross? - i guess thats "kinda" good news...
I probably wont run the cam , hope to MAYBE go to a roller , i guess its back to pb&j / hotdogs for dinner for a couple months...
Ted - tryin to talk Jimmy Mopar into flexhoning the bores (i dont have a flex hone---need to buy one i guess) , plus i wouldnt mind him or Steve putting another set of eyeballs on my junk while its apart .... Im sure i will miss something...
if i put a roller in this thing yer never gonna catch me in that ol Dodge of yours......
Re: Your opinions Please- my motor is finally apart ! [Re: 493_DART] #547800
12/22/09 11:12 AM
12/22/09 11:12 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Roller Roller Roller
Re: Your opinions Please- my motor is finally apart ! [Re: Al_Alguire] #547801
12/22/09 12:29 PM
12/22/09 12:29 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Flex hones leave too rough a surface. I'd have it professionally properly honed if it needs it. With that little time it may not. I've used scotchbrite wrapped around a rigid hone to get a fresh surface and clean the bores without going appreciably bigger.
Re: Your opinions Please- my motor is finally apart ! [Re: moper] #547802
12/22/09 01:08 PM
12/22/09 01:08 PM
Q
Quicktree Offline
Quicktree  Offline
Q
only 182 passes and you need a freshen up who can afford that? we have almost put that many just testing nad getting things sorted out.
Re: Your opinions Please- my motor is finally apart ! [Re: Quicktree] #547803
12/22/09 01:46 PM
12/22/09 01:46 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Quick, that`s why I asked WHY?
Re: Your opinions Please- my motor is finally apart ! [Re: Quicktree] #547804
12/22/09 05:07 PM
12/22/09 05:07 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
you cant afford $250 for rings/bearings ??
sorry to hear that.
It takes you 182 passes to sort out a car ?
Maybe I can come down and help ya out . I like Florida.
Re: Your opinions Please- my motor is finally apart ! [Re: 493_DART] #547805
12/23/09 12:46 AM
12/23/09 12:46 AM
Q
Quicktree Offline
Quicktree  Offline
Q
sorry to hear that.
yea you do that but I promise the motor womt be coming out until about 350 more passes
Re: Your opinions Please- my motor is finally apart ! [Re: 493_DART] #547806
12/23/09 01:04 AM
12/23/09 01:04 AM
Q
Quicktree Offline
Quicktree  Offline
Q
sorry to hear that.
oh yea, sounds like you better do some more sorting I have already out run you with half the motor
Re: Your opinions Please- my motor is finally apart ! [Re: Quicktree] #547807
12/23/09 03:21 AM
12/23/09 03:21 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
Thats cool
post your combo Quicktree , maybe i can learn something from you.
"half the motor" would be...what.....a 383 or smaller with a 509 cam or smaller / pump gas / n/a , around 9:1 max ?
is that about right ? cuz i dont have a lot in this motor....
Post deleted by Defbob [Re: Quicktree] #547808
12/23/09 04:54 AM
12/23/09 04:54 AM
