Need a quick & easy way to figure out gear ratio #547220
12/06/09 06:43 PM
12/06/09 06:43 PM
Woodbridge,CA
NAS Backyard Offline OP
Woodbridge,CA
I was doing to old car shuffle getting ready to move this project to the other side of the backyard for longer term storage, and I discovered it has a Sure Grip in it I believe. No tags. The yoke is 3 1/2" wide, is that small or large, I can't remember. Anyway I have the car jacked up with the wheels on it and I can turn the driveline. How do I figure out the ratio? I may have to "borrow" this gear for awhile if its a 3:55 It was probebly changed at one point. The car came with a 318/904. Would it be on the fender tag?Thanks
1970 Challenger Ragtop 426 4 speed 1961 Olds 88 2 dr Sedan 394 4 speed GVOD 1968 Pontiac Firebird 428 4 speed 2000 Ford F-150 2002 HD Roadking 1961 Licence Plate collection 1995 Buick Roadmaster www.nogreenautolaws.com
Re: Need a quick & easy way to figure out gear ratio [Re: NAS Backyard] #547221
12/06/09 06:48 PM
12/06/09 06:48 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Turn the wheel once around and count the number of times the driveshaft rotates. 3 1/2 turns is a 3.55,3 1/4 turns is a 3.23 etc. That works if it's a sure grip. Both wheels will turn the same direction if it's a sure grip.
Re: Need a quick & easy way to figure out gear ratio [Re: stumpy] #547222
12/06/09 07:04 PM
12/06/09 07:04 PM
Woodbridge,CA
Woodbridge,CA
Thanks stumpy! Looks like it's a 3:55, but it's a small yoke. I may leave it in the shop for awhile and get it running so I can move it around under it's own power.It hasn't ran a in 10 years but it ran when it was parked.
Re: Need a quick & easy way to figure out gear ratio [Re: NAS Backyard] #547223
12/06/09 07:40 PM
12/06/09 07:40 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
There is nothing wrong with the small yoke.
Re: Need a quick & easy way to figure out gear ratio [Re: stumpy] #547224
12/06/09 08:22 PM
12/06/09 08:22 PM
Michigan Troll
blk00rt Offline
blk00rt  Offline
Michigan Troll
any tricks for figuring out gear ratio on an open rear end?
Rob Dunn
1976 Dart Sport 360
2000 dakota RT 408 with 150 nitrous
2013 Dodge Ram 1500 Hemi
2009 Jeep Patriot
Re: Need a quick & easy way to figure out gear ratio [Re: stumpy] #547225
12/06/09 08:43 PM
12/06/09 08:43 PM
Woodbridge,CA
Woodbridge,CA
My RR has the larger yoke, so it wouldn't be a quick swap, although they are both 489 cases. Would it be a big hassle to change out the yokes? I know those nuts don't come off too easy. I like the way this looks. The Challenger belongs to the guy who painted my car, I can pretty much do anything I want with it. Are plan was to put the roof on it , get it running, and sell it. I really don't need another money pit though.
Re: Need a quick & easy way to figure out gear ratio [Re: blk00rt] #547226
12/06/09 08:58 PM
12/06/09 08:58 PM
Just jack one tire off the ground and rotate the wheel 2 full turns counting how many times the yoke turns...........3:55 will rotate roughly 3.5 turns....
Re: Need a quick & easy way to figure out gear ratio #547227
12/06/09 09:00 PM
12/06/09 09:00 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Just change to the combo Ujoint. http://www.moparts.org/Tech/Archive/shaft/4.html
Re: Need a quick & easy way to figure out gear ratio #547228
12/06/09 09:41 PM
12/06/09 09:41 PM
Michigan Troll
blk00rt Offline
blk00rt  Offline
Michigan Troll
thanks, Ill be doing that this week.
Rob Dunn
1976 Dart Sport 360
2009 Jeep Patriot
Re: Need a quick & easy way to figure out gear ratio [Re: stumpy] #547229
12/06/09 10:35 PM
12/06/09 10:35 PM
Woodbridge,CA
Woodbridge,CA
Problem with that is I already have a combo GM/Mopar u-joint because of my Gear Vendors, So I would need a totally different u-joint, however I'm sure theres one out there somewhere. I'll check it out.
Re: Need a quick & easy way to figure out gear ratio [Re: NAS Backyard] #547230
12/06/09 11:12 PM
12/06/09 11:12 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Why would you need a different one. You would only be replacing the rear joint not the gear vendor end or does GV use a GM joint on both ends of the shaft?
Re: Need a quick & easy way to figure out gear ratio #547231
12/07/09 12:19 AM
12/07/09 12:19 AM
Texas
Texican Offline
Texican  Offline
Texas
1.) Jack the rear end of the car up on stands and place the tranny in neutral.
2.) Spin the draveshaft so that one of the bolts is on the top - dead center...and Mark it (crayon...grease...spit...etc..)
3.) Place a mark on one of the tires (anywhere)
4.) For an open rear end, spin the tire "exactly" two full turns and carefully count how many times the driveshaft goes round. When the tire has made it's second revolution (stop on the same exact "tire" mark)... Determine if the driveshaft has gone around 3.5 times or 2.7 times....or 4 times... etc...
For a posi rear end, spin the tire only once.
Re: Need a quick & easy way to figure out gear ratio [Re: stumpy] #547232
12/07/09 02:14 AM
12/07/09 02:14 AM
Woodbridge,CA
Woodbridge,CA
The GV had a GM yoke so I have the shaft made with GM sizes on both ends not thinking what I would be doing in the future. The driveline guy suggested the GM/Mopar joint. I should have made it a Mopar end. But I can still have them change the end to a Mopar if theres not a conversion joint available, and run the Moper conversion joint. It's just a matter of spending the money.
