Re: 340 pistons to 360 block ?????
[Re: RAY1969CARS]
#547114
12/06/09 04:59 PM
12/06/09 04:59 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
.135" higher than it was in the 340 block.
This is if you are using the 360 stock stroke crank. I know a guy with this combo. I think he had to clearance the piston some.
I would spend money on a set of pistons instead.
[Re: dragnduster]
#547118
12/06/09 06:02 PM
12/06/09 06:02 PM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
you will have to make room for the 360 counter weights...they will strike teh skirt..Pin pad fwiw cheapst.
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
