Brake Proportioning Valve question B-body on A-body? #546949
12/06/09 12:57 PM
12/06/09 12:57 PM
Pennsylvania
craigerlitz Offline OP
Pennsylvania
I was wondering if there would be any problems with using a proportioning valve from a 74 B-body that had disk brakes on an A-body car using the '73 and up disk brakes?
Thanks,
Craig
Re: Brake Proportioning Valve question B-body on A-body? [Re: craigerlitz] #546950
12/07/09 01:39 AM
12/07/09 01:39 AM
Vista, California
ChickMaggot Offline
ChickMaggot  Offline
Vista, California
I'm no brake expert, but I would thnk that a valve spec'd for a heavy car may be a bad match if used in a car that was much lighter.
Maggot
You can lead a gift horse to water, but you
can't look in his mouth.
Re: Brake Proportioning Valve question B-body on A-body? [Re: craigerlitz] #546951
12/07/09 11:47 PM
12/07/09 11:47 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
I've used the Brass F body ones on A body cars.More along the same weight as an A body. PM me if interested.
