Progress Pics Procharged Runner. Ever had plan GROW!
#546592
12/05/09 10:21 PM
12/05/09 10:21 PM
Posts: 4,243 Canada
Kam*Kuda
Canada
Slowly the plans for the Road Ruiner have come together. It started at Norwalk Ohio, Meeting GREAT people and having fun. I got to do this. So I had a spare 440 and bought a Road Runner shell It started simply but kinda grew to be more than planned. "well since you are planning on going faster in the future, we may as well: - add a dana - upgrade the fuel system - add a 10 point cage What was I thinking... Procharger! - bought a used D1X Procharger on Ebay, (and I saw how nice the Stig Jrs Road Runner ran) - Since you are boosting , should go to EFI - A mega block is a good idea. Sod the 440 bought a 500 inch - Better upgrade the fuel system again - add a motor plate - etc etc Having collected a lot of parts and the street strip car is coming together. This is where it sits today and I will work backwards. (I am glad I have a great and tolerant wife)
1970 Barracuda Convertible 1968 Satellite Street Strip car 1654.5 Mustang 1955 Land Rover
Re: Progress Pics Procharged Runner. Ever had plan GROW!
[Re: Kam*Kuda]
#546593
12/05/09 10:22 PM
12/05/09 10:22 PM
Posts: 4,243 Canada
Kam*Kuda
Canada
Here isthe Engine Bay, Some cool modifications. I will draw some arrows to mods. Carved the tunnel Holes for a clean brake line system Procharger hole Bar thru inner fender, you can see it on the other side in previous pic Modified Shock Tower READY for PAINT! Finally
[Re: Kam*Kuda]
#546594
12/05/09 10:26 PM
12/05/09 10:26 PM
Posts: 3,831 N.E. Ohio
6bblFLASH
N.E. Ohio
Sounds like you are having fun. At least you are smart enough to make changes AS you build. I rethink everything AFTER I`m done. Keep us posted.
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
[Re: Kam*Kuda]
#546596
12/05/09 10:30 PM
12/05/09 10:30 PM
Posts: 8,647 ELYRIA,OH
blownzoom440
ELYRIA,OH
keep up the good work.it will be togather soon! what color will she be?
[Re: Kam*Kuda]
#546600
12/05/09 10:35 PM
12/05/09 10:35 PM
Posts: 4,243 Canada
Kam*Kuda
Canada
Here is the Air Plumbing and EFI mocked up Using a victor intake predrilled for EFI. I changed my mind on the elbow for the throttle body and got a low profile version. It was too short and I had to add a spacer to fit between the throttle body and the intake. The whole set up fits almost under a stock hood. You can see the blow-off mounted to the intercooler. Fiberglass Bumpers (with a ton of work to make the right, ) I will open up the area where the license plate normally goes for additional air flow.
[Re: Kam*Kuda]
#546605
12/05/09 10:57 PM
12/05/09 10:57 PM
Posts: 4,243 Canada
Kam*Kuda
Canada
Procharger bracket. I may as well switch from the 10 rib right to the cog set up. more $$$
[Re: Kam*Kuda]
#546607
12/05/09 11:22 PM
12/05/09 11:22 PM
Posts: 4,243 Canada
Kam*Kuda
Canada
Here was the original mounting for the procharger, Switched sides, more room on the passenger side.
[Re: Kam*Kuda]
#546608
12/05/09 11:23 PM
12/05/09 11:23 PM
Posts: 4,243 Canada
Kam*Kuda
Canada
UPDATED--- Modified K frame, Now with Wilwood brakes.
[Re: Kam*Kuda]
#546611
12/05/09 11:49 PM
12/05/09 11:49 PM
Posts: 12,129 Cleveland
sunroofgtx
Cleveland
Looking awesome. Robbie, I am thinking about starting to collect parts. Where did you find your mounting brackets? What compression are your slugs?
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
