Re: Fiberglass Resin
[Re: elitecustombody]
#546128
02/16/10 10:47 PM
02/16/10 10:47 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Acetone, rags and elbow grease will clean out the ooze.
[Re: RAT PATROL]
#546133
02/18/10 01:32 AM
02/18/10 01:32 AM
Posts: 1,572 Jacksonville Florida
elitecustombody
I have to figure out a way to fill the holes from the bottom now, maybe glue some plugs in or something. It's only two holes per side,and they are sealed on top with cloth and resin, but it bothers me that I bungled the job.
grind the edges of the holes,prep the area,take the mat and pull strands,don't cut or chop, just rip and mix them in the resin with stick till it becomes a paste,pack it in the holes and use some masking tape over the are till cured, you can also add some Aerosil filler,it's a fumed silica, most marine stores will have it
