Fiberglass Resin #546118
12/05/09 04:39 PM
12/05/09 04:39 PM
Oregon,USA
RAT PATROL Offline OP
Oregon,USA
I mixed up some resin and hardener to fill in the wrong seat holes. Covered the bottom of the holes with tape, filled the holes with resin, laid cloth over it, smeared resin around it. Guess what, it's not setting up, apparently not enough hardener,It's messy. Yes the wife has already informed me that I'm a real genius. What's my way out of this boo boo?
Re: Fiberglass Resin [Re: RAT PATROL] #546119
12/05/09 04:51 PM
12/05/09 04:51 PM
Oregon,USA
Oregon,USA
I'm just lucky the wife doesn't golf.
Re: Fiberglass Resin [Re: RAT PATROL] #546120
12/05/09 05:55 PM
12/05/09 05:55 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
try putting some heat on it...
I am truckless..
Re: Fiberglass Resin [Re: RAT PATROL] #546121
12/05/09 06:17 PM
12/05/09 06:17 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
What kind of temperature are you working in ? ....did you actually measure-out the hardener? ... MAT(instead of cloth) is best-er for doing something like this.
Re: Fiberglass Resin [Re: dOoC] #546122
12/05/09 08:03 PM
12/05/09 08:03 PM
Oregon,USA
Oregon,USA
It's about 50 in the garage. Of course I measured the hardener, 8 drops, about a cup of resin, or cup and a half, I don't really remember after all the fumes. I tried using a heat gun the next day, but it seemed to soften it up. Maybe I'll try a heat lamp tonight. What is MAT?
Re: Fiberglass Resin [Re: RAT PATROL] #546123
12/07/09 12:36 AM
12/07/09 12:36 AM
Oregon,USA
Oregon,USA
I mixed up a new hot batch, poured it over the soft stuff, let it sit overnight with a heatlamp, perfect, done. Next up armaflex interior.
Re: Fiberglass Resin [Re: RAT PATROL] #546124
12/09/09 01:34 PM
12/09/09 01:34 PM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
Sorry I missed this til now .... in 50 degree temps .. you should not have to use a heat lamp. Plus .. using a heat lamp will not allow the best bonding of the new to old material.
Mat ? .. is a thicker material that will conform better to irregular surfaces.
Re: Fiberglass Resin [Re: dOoC] #546125
02/14/10 09:06 PM
02/14/10 09:06 PM
Jacksonville Florida
elitecustombody Offline
8 drops per cup? on smaller repairs I usually add a little more than 2% and I'm with Doc, heat lamp can do more damage than help, a little heat to warm up the part is OK, but not so much heat that you see smoke and blisters,
did you bevel the edges of the holes?
Re: Fiberglass Resin [Re: elitecustombody] #546126
02/16/10 11:21 AM
02/16/10 11:21 AM
Oregon,USA
Oregon,USA
No, I didn't bevel the holes. It gets better, when I put a new layer of resin and glas on top it seemed to do the job, so I continued on to insulate the floor, however when I took the tape off the bottom of the holes the unhardened resin inside the holes oozed out.
Re: Fiberglass Resin [Re: RAT PATROL] #546127
02/16/10 06:34 PM
02/16/10 06:34 PM
That doesn't sound good
Re: Fiberglass Resin [Re: elitecustombody] #546128
02/16/10 10:47 PM
02/16/10 10:47 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Acetone, rags and elbow grease will clean out the ooze.
Don't be the exception.
Re: Fiberglass Resin [Re: Supercuda] #546129
02/17/10 09:56 AM
02/17/10 09:56 AM
Oregon,USA
Oregon,USA
I have to figure out a way to fill the holes from the bottom now, maybe glue some plugs in or something. It's only two holes per side,and they are sealed on top with cloth and resin, but it bothers me that I bungled the job.
Re: Fiberglass Resin [Re: RAT PATROL] #546130
02/17/10 11:56 AM
02/17/10 11:56 AM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
get some fiberglass matting and shred it up. mix it with the resin and put it in the holes from underneath. it should stick in there without any problems.
Re: Fiberglass Resin [Re: 65rbdodge] #546131
02/17/10 08:42 PM
02/17/10 08:42 PM
Oregon,USA
Oregon,USA
I'll try it, Thanks boss.
Re: Fiberglass Resin [Re: RAT PATROL] #546132
02/18/10 01:11 AM
02/18/10 01:11 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
Fiberglass resin gel has a more body than standard liquid resin and will spread more like body filler.You can cut 'glass mat or cloth and mix it with the gel for more strength.Tape wit wax paper over the hole will keep the material in place until dry.
RT
Re: Fiberglass Resin [Re: RAT PATROL] #546133
02/18/10 01:32 AM
02/18/10 01:32 AM
grind the edges of the holes,prep the area,take the mat and pull strands,don't cut or chop, just rip and mix them in the resin with stick till it becomes a paste,pack it in the holes and use some masking tape over the are till cured, you can also add some Aerosil filler,it's a fumed silica, most marine stores will have it
Re: Fiberglass Resin [Re: elitecustombody] #546134
02/18/10 11:01 AM
02/18/10 11:01 AM
Oregon,USA
Oregon,USA
Thanks guys, much appreciated!
