Re: oil pickup
[Re: bonefish]
#545751
12/05/09 12:37 PM
12/05/09 12:37 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
I ground mine...Is it a standard 2.375 journal rods? It will clear the pickup if its 3/8 NPT. Grind enough to clear by atleast .050 or so.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
Re: oil pickup
[Re: Bob_Coomer]
#545754
12/05/09 10:01 PM
12/05/09 10:01 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
I know a few guys that cut & weld the pick up to clear.
That might work on some but....... It wont matter, it's not the pickup that hits..Its the rod bolt hitting the oil galley boss where the pickup screws in the block... Atleast thats what hit in mine..Now with 2.2 cranks, they dont come close. It was probably 2003 when I assembled that particular engine..so its hard to recall some details.
no, its actually hittin the pu tube,i really dont want to grind on a rotating assby. i just had balanced.
Re: oil pickup
[Re: rowin4]
#545759
12/06/09 10:04 AM
12/06/09 10:04 AM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
Heat the tube with a torch and take a pair of channel locks to narrow the area thats hitting. Tube isn't very thick to do much grinding on.
this sounds like a good idea
