Yeah, there is an slight angle difference between the early & late. We compared the original early on the car with the late lower BJ & the early had a slight upward angle at the tie rod end compared to the later one.
We still used the later style & have had no issues, you'd have to have the front end way out from stock height to ever get near the end of travel on the tie rod end. Kinda like the discussion about the taller spindles.
The later is a bunch cheaper too. We used everything late in a 65 Valiant for the disc conversion with the exception of pitman / idler & original center link.
Forgot....the early & late both would bolt up the spindle so that's the same.
Butch
