transmission seals #544719
12/04/09 11:00 AM
12/04/09 11:00 AM
michigan
70 buzz Offline OP
70 buzz  Offline OP
michigan
Where can I buy the seals that go here in the picture. Thanks
Re: transmission seals [Re: 70 buzz] #544720
12/04/09 11:02 AM
12/04/09 11:02 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
those are O rings , a hardware store will have them , or an auto parts store might be better so you get the correct ones for use in a oil soaked enviorment .
Re: transmission seals [Re: 70 buzz] #544721
12/04/09 11:51 AM
12/04/09 11:51 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Call Brewer's Performance 937-698-4259 Wayne or Dan will be able to help.
You may need some gaskets & other seals to while you have it out.
Just my
