Re: 426 Hemi pulleys?
[Re: PJM]
#544544
12/05/09 04:33 PM
12/05/09 04:33 PM
Posts: 75,060 U.S.S.A.
JohnRR
U.S.S.A.
So they are all the same? I have a 528 crate motor so I am not using a stock balancer. Do I need the spacer? Thanks
Whose crate motor and are you going for the OEM RESTO look ?
[Re: PJM]
#544547
12/05/09 07:49 PM
12/05/09 07:49 PM
Posts: 1,247 Fremont, CA.
Topcat
Fremont, CA.
Balancer looks to be about 1 1/2'+ wide. Cant get an exact measurement tonight w/o my glasses. lol
Put your glasses away. This should be easy to clarify.
It should either look like its about an inch thick or if it's the other, then it loks like it's almost 2 inches thick.
[Re: PJM]
#544550
12/06/09 02:19 AM
12/06/09 02:19 AM
JohnRR
U.S.S.A.
If theres only two. Its the thicker one. Its 1 1/2' inches thick.
Put your glasses on , is the hub recessed ? What year is the car it's going in ?
