Racking up miles on a 5.7 hemi..any problems to expect? #543500
12/02/09 09:18 PM
12/02/09 09:18 PM
NC
DCM71cuda Offline OP
NC
My 06 Ram has about 130K on the odometer. I have every intention of driving it for a lot longer.
I've always done fluid/filter/plug changes as needed. Now that the miles are creeping up, are there any 'known' issues that come up?
Water pump, alt, etc?
Thanks for any info.
Re: Racking up miles on a 5.7 hemi..any problems to expect? [Re: DCM71cuda] #543501
12/04/09 09:59 PM
12/04/09 09:59 PM
NC
NC
Re: Racking up miles on a 5.7 hemi..any problems to expect? [Re: DCM71cuda] #543502
12/04/09 11:58 PM
12/04/09 11:58 PM
IN
ahy Offline
ahy  Offline
IN
I guess no news is good news? I'm around 120k and plan to keep mine. I replaced a tired thermostat so far but that's it.
Re: Racking up miles on a 5.7 hemi..any problems to expect? [Re: ahy] #543503
12/05/09 01:00 AM
12/05/09 01:00 AM
Canuckville
68Cbarge Offline
68Cbarge  Offline
Canuckville
102k and overdue for servicing.
No major problems here..
'68 Newport Custom Barge on a Budget!! BOAB
1973 Satellite WAGON! 318- 3 on the tree!!
2008 Chrysler 300c HEMI!
Re: Racking up miles on a 5.7 hemi..any problems to expect? [Re: DCM71cuda] #543504
12/05/09 11:07 AM
12/05/09 11:07 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
you might look over the TSB's for Rams here:
http://dodgeram.info/tsb/index.html
especially for your model year,
but it is worth a quick glance
for all model years above 2002
if you have a 1500
keep a close eye on the 9.25 differential
especially the big nut becoming un-torqued
which leads to both the seal failing,
and the pinion bearing ruined
Good Luck
