Any issue with 2.14/1.81 valves on a 4.280 bore? #543208
12/02/09 06:31 PM
12/02/09 06:31 PM
IL
furious70 Offline OP
IL
Seems like I've read threads about 2.14/1.81's on a 383 being a problem? Is it 'only' a problem of valve shrouding, or are there actual interference concerns at certain lifts?
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Any issue with 2.14/1.81 valves on a 4.280 bore? [Re: furious70] #543209
12/02/09 06:45 PM
12/02/09 06:45 PM
central Ohio
SnakeEisz67 Offline
SnakeEisz67  Offline
central Ohio
I did this in the past with no interference issues. Maybe was due to fact cam wasn't too big? I was running MP Purple cam 533/320 hydraulic cam at the time.
Re: Any issue with 2.14/1.81 valves on a 4.280 bore? [Re: furious70] #543210
12/02/09 06:51 PM
12/02/09 06:51 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
I'm running that combo with no apparent issues...
Re: Any issue with 2.14/1.81 valves on a 4.280 bore? [Re: 64Post] #543211
12/02/09 07:06 PM
12/02/09 07:06 PM
IL
IL
maybe I'm remembering a thread about possible shrouding and loss of power then vs. a mechanical interference issue....
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Any issue with 2.14/1.81 valves on a 4.280 bore? [Re: furious70] #543212
12/02/09 08:01 PM
12/02/09 08:01 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Get out your die grinder, just make sure you stay above the ring travel.
Re: Any issue with 2.14/1.81 valves on a 4.280 bore? [Re: furious70] #543213
12/02/09 08:40 PM
12/02/09 08:40 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
The olde MP and DC race manuals always said that combo wouldn't work.I ran 452's with the large valves on a 383 and it did fine.
Nautilus Racing-
Re: Any issue with 2.14/1.81 valves on a 4.280 bore? [Re: Chris2581] #543214
12/02/09 08:46 PM
12/02/09 08:46 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I think they meant the 1.88 exhaust valve.
We had eddies (2.14/1/81) on my buddies 413 bored to 4.250 and it ran 11.8's so Fine you bet!!
Re: Any issue with 2.14/1.81 valves on a 4.280 bore? [Re: Dodgem] #543215
12/02/09 08:49 PM
12/02/09 08:49 PM
UK
602heavy Offline
602heavy  Offline
UK
Not had a problem , had @ least 3" lift without any bore interference.
Re: Any issue with 2.14/1.81 valves on a 4.280 bore? [Re: 602heavy] #543216
12/02/09 10:09 PM
12/02/09 10:09 PM
IL
IL
great, thanks guys
70 Sport Fury
68 Charger
69 Coronet
72 RR
