The best junkyard starter for a 440 #542560
12/01/09 11:02 PM
12/01/09 11:02 PM
Minnesota, USA
minnesota guy Offline OP
Minnesota, USA
I bought a 35.00 3.9 liter starter from 99 dodge dakota at junk yard...supposed to be same as 316 from that year...it is chrysler japandenso...
are there some better ones out there that crank faster? in junk yard variety? thanks,,,
Re: The best junkyard starter for a 440 [Re: minnesota guy] #542561
12/01/09 11:20 PM
12/01/09 11:20 PM
Marion Illinois
72d100 Offline
72d100  Offline
Marion Illinois
i Think all magnum starters are high torque mini starters. when i ordered mine for my 400 i got one for a dakota with a 318, works awsome
Re: The best junkyard starter for a 440 [Re: minnesota guy] #542562
12/01/09 11:33 PM
12/01/09 11:33 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
That one should work fine.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: The best junkyard starter for a 440 [Re: HemiRick] #542563
12/02/09 02:05 AM
12/02/09 02:05 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I think all the minis are pretty close. I yanked a mini out of a ram van. Works great.
Re: The best junkyard starter for a 440 [Re: minnesota guy] #542564
12/02/09 02:10 AM
12/02/09 02:10 AM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Look for the longer version of the starter that has more windings.
Re: The best junkyard starter for a 440 [Re: moparpollack] #542565
12/02/09 08:04 AM
12/02/09 08:04 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
you will need to do some grinding on the case so you can get the bottom bolt in.
Coming soon!!!!
Re: The best junkyard starter for a 440 [Re: Mr.Yuck] #542566
12/02/09 01:22 PM
12/02/09 01:22 PM
Bowie, MD
Reggie Offline
Reggie  Offline
Bowie, MD
I saved the info below which was originally posted here by member dennis3866.
Here is some info that I saved on this topic from some time ago. I cannot vouch for the accuracy but the info is very detailed. Here it is:
HI GUYS , i re-posted the prior post with all the part numbers ...hot number in re-built for a 383/440 mtr , is the 17466, or just get one from jack kirkland , i think his new ones are evn cheaper than the re-builts .....
posted 8/2001 nipponsenzo starters ; re-builts and new for all mopar v-8s please read, there is a difference
ok guys here's the deal...i tried over the last 3 weeks 4 rebuilt starters in a row ,
for my 440 , univ numbering system on the rebuilts is 17084, which is for a 89 dodge diplomat 318 v-8, nippo starter ...they WONT start a 440 ON EVERY TURN OF THE KEY, they click , then start the car then click, then start the car etc, etc ..., or at least the ones i bought wouldnt , REASON; the shaft and throw-out gear hooked to the clutch in the starter wont shoot out far enough to engage the flywheel on the 440 every time ; fine for a small blk, and its the 1.4kw hi-output too, but ng for the 440, and 383 also ....
The correct REBUILT NUMBER for the 440 and 383 , is the number 17466, which a bit smaller in overall size than the 17084, and has approx a 1/8in longer inside snout nose to shoot the shaft out farer and engage the flywheel teeth on the 383 and 440, ...and it will also fit the sml blocks as well ....but that is the correct number, andits application is for the 95' and up Dodge ram full size p/u's w the v-8's,numbered as 17466 ; ...the 2 re-built starters even look the same , except when u put them side-by-side and look closely at them ...if u put the 17084 and the 17466 side by side , u'll find the 17466 is a shade shorter , and a shade narrower, w a shade shorter armature housing ...the 17466 is THE HOT SET-UP FOR WEDGES AND SMALL BLOCKS TOO ; IT WILL FIT BOTH ...whenever possible on the rebuilts , try and get the 1.4kw starter vs the .84kw starter ,especially on a higher comp motor ; on anything under 10.5-1 comp , it wont matter anyway ....as far as new goes, power master sells them , and MP sells them also , but they are a lil pricey; ...i found a nice gentleman , named jack kirkland , aka ' 500amp ', calls his company , auto electric in no. michigan ...he sells new , take off , chry nippondenzo starters C H E A P ,at ONLY 89.00...new, not rebuilt ....i bought a couple from him , got them in 3 days , and they are new nippo's, and are the hi-output ones , and WILL START our 440 and 383 engines ....they are brandie new , and cost less from him than the rebuilts cost me wholesale from a distributor ...so if ya want a good deallook up mr kirkland ....he can be found selling his wares on ebay , under 'mopar starters ', or 'starters', and is called the 500 amp man....he's the only one selling NEW chry starters , and advertises them as take-off's...look u'll find him i did ....and his starters are excellent.
A LITTLE NOTE ; on the 440 and probably the 383 engines also , the positive starter stud sticks up a 1/8-1/4in to high and just touches the block...U DONT WANT THAT , IT'LL GROUND OUT ....JUST , trim down the top of the stud with a whizzer or a hack saw , clean up the threads, and voila , problem cured ....i know this for fact on the new starters from mr kirkland , and probably applies to any new mopar starter on a 440 or 383 , the re-builts that i used didnt have this problem because of a diff stud arrangement , but be careful nonetheless... happy moparing
First of all 17466 and 17084 are only LESTER part numbers, parts stores use them. They are a generic parts I.D number. Manufacturers and their part number for the 17466 are; ARC-#S1766, ARROW-#35-2414, BOSCH-#SR6504X, CHRYSLER-#53005984, LUCAS-#S2403,NIPPONDENSO-#'s 128000-781, 128000-7810, NIPPONDENSO remanufactured-#9712809-781, PIC-#190-365, WAI-#2-1383-ND, 2-1398-ND,2-1398-ND-1.....
Chrysler doesn't make their own so it will have their number plus one of the others.
Here is the list of vehicles they were on;
Dodge B-series van 3.9L 5.2L 5.9L...'91-'95
Dodge D-series p/u 3.9L 5.2L 5.9L...'91-'93
Dakota.............3.9L 5.2L........'91-'95
Ram p/u............3.9L 5.2L 5.9L...'94-'95
Ramcharger.........5.2L 5.9L........'91-'93
W-series...........3.9L 5.2L........'91
W-series...........3.9L 5.2L 5.9L...'92-'93
That's what I have on the 17466, Lucas uses the same part number for both 17466 and 17084. #17466 is 21mm shorter and the case is notched out by the gear so its exposed more. Hope this helps.
Re: The best junkyard starter for a 440 [Re: Mr.Yuck] #542567
12/02/09 04:22 PM
12/02/09 04:22 PM
Manitoba, Canada
Manitoba, Canada
I didn't need to grind anything on the case, however I needed to grind down the studs for the power wire hookups to the starter so they wouldn't hit the side of my 440's block. Cut them down a bit, had to cut down the big one quite a bit, then clean up the threads a little. The nut still gets full thread engagement but not any extra stud sticking out anymore. Works great and no problems. At one time I thought the starter was junk, but turned out to be a slowly discharging battery due to a faulty voltage regulator.
Re: The best junkyard starter for a 440 [Re: DaytonaTurbo] #542568
12/02/09 05:22 PM
12/02/09 05:22 PM
Grand Rapids, MI
11secondC Offline
11secondC  Offline
Grand Rapids, MI
I'm running a starter from a '94 3.9 Dakota, been there 5 years, best 20 bucks I ever spent, had to modify the plastic cover/shroud for the post but other than that works flawlessly.
Re: The best junkyard starter for a 440 [Re: minnesota guy] #542569
12/02/09 05:39 PM
12/02/09 05:39 PM
N.Wilkesboro,NC
DusterKrazy Offline
DusterKrazy  Offline
N.Wilkesboro,NC
On the mini starters, I noticed that some have a the terminals that will hook right up. Others I have noticed use a plug in style setup. How do you set one of those up? Any pics?
Re: The best junkyard starter for a 440 [Re: DusterKrazy] #542570
12/02/09 10:14 PM
12/02/09 10:14 PM
Manitoba, Canada
Manitoba, Canada
You just take the plastic plug section off and it's a normal starter under there IIRC.
Re: The best junkyard starter for a 440 [Re: Mr.Yuck] #542571
12/03/09 10:31 PM
12/03/09 10:31 PM
Minnesota, USA
Minnesota, USA
No, it fit right in.440...4spd application 440 1977 cast iron bell housing...
