Re: '70 Duster Front Sway Bar Bracket Loops..Any Repops?
[Re: gtx6970]
#542379
12/02/09 12:08 AM
12/02/09 12:08 AM
Posts: 27,480 So Cal
autoxcuda
So Cal
Ok, this might be a stupid question, but whats the difference between B and A bodies ?
B-bodies are avail http://www.rtspecialties.net/proddetail.asp?prod=2535990
I pretty positive that would be the same part for a 73-76 A-body with sway bar.
I also think the bracket (loop) is the same for 67-72 A-bodies as 68-69 B's as shown in that link. The sway bar diameter is slightly different, but I bet the bushing ID is the only difference.
I remember a restorer stealing them off of A-body sway bar to use on 68-69 B's. -carefully cutting and rewelding them and using the A-body bushing.
[Re: Steve340]
#542381
12/02/09 12:30 AM
12/02/09 12:30 AM
autoxcuda
So Cal
I am surprised no one is making early A-body sway bar brackets and bushings. Over the years they get smashed from hitting the parking curb. Not to mention, the original rubber bushings are worn out on all these cars. Someday maybe they will be available from someone. If the E-bodies used the same style, they would have been made years ago.
They are much harder to reproduce. Wouldn't you have to reproduce the injection molded rubber too. Or maybe you could use the poly repro. Even with a perfect new welded bracket the polys are very tough to install.
I know the person who repro'd the ones shown above on the RTSpecialties site. He knew full well the earlier one is needed more. But repro cost and difficult end user application made him choose the easier to do part. I don't think they made the earlier style poly bushings at that time either.
[Re: 44D6PAKCUDA]
#542385
12/08/09 08:26 PM
12/08/09 08:26 PM
340dart4spd
Parts Problem
Parts Problem
Is anyone repopping the front triangle shaped sway bar mounting loops and bushings?The ones that bolt to the k-frame for a '70 Duster? Thanks!
how many do you need.. I have one loose one
