Zinc Additive
#542329
12/01/09 08:10 PM
12/01/09 08:10 PM
Posts: 992 Simi Valley, CA
MoparJ
Simi Valley, CA
Would using 15w40 Chevron Delo with STP additive contain enough zinc to safely operate with a flat tappet Comp cam? I am currently running Valvoline VR1 20w50, which has lots of zinc, but want to run a thinner oil to pick up some power and fuel mileage.
2016 Ram 1500 Crew Cab: 5.7, 65RFE, 4.56 gears with locker, Hemifever tuned, AFE intake, 87mm throttle body, JBA headers, 3" Flowmaster exhaust, split to dual 2.5" exits. 13.57 best ET so far.
Searching for new A or B Body Project!
Re: Zinc Additive
[Re: MoparJ]
#542330
12/01/09 08:30 PM
12/01/09 08:30 PM
Posts: 2,179 S.E. Conn
Hoof Hearted
S.E. Conn
I run 15/40 Rotella and plan on going down to the Rotella 5/30 for the same reasons.
2005 300C Hemi 2014 Ram ProMaster 2500
I Rekey, Repin old Chrysler locks and cut keys by code
Re: Zinc Additive
[Re: MoparJ]
#542331
12/01/09 08:37 PM
12/01/09 08:37 PM
Posts: 8,716 Baltimore/Denver
64Post
Baltimore/Denver
Justin,
Brad Penn 30w may work for you. I use it with a very aggressive FT cam. IIRC, Isky sells ZDDP as an additive if you want to go that route.
Re: Zinc Additive
[Re: MoparJ]
#542332
12/01/09 09:28 PM
12/01/09 09:28 PM
Posts: 10,210 Someplace you aren't
SomeCarGuy
Have the place you get the ZR1 now order you in some in 10w-30 or whatever. I know they make other weights, just most places stock the heavy stuff.
I want my fair share
Re: Zinc Additive
[Re: SomeCarGuy]
#542333
12/02/09 12:34 PM
12/02/09 12:34 PM
Posts: 2,754 Conway, SC
T2R9
Conway, SC
I had my local Napa order me 10w-30 VR1 for my cars.
Re: Zinc Additive
[Re: MoparJ]
#542335
12/02/09 01:31 PM
12/02/09 01:31 PM
Posts: 5,443 Indiana
YO7_A66
Indiana
I used to run the Rotella 15/40 Rotella but it was too thick causing the lifters to tick after a WOT run. I now run the Synthetic Blend 10/30 Rotella with a bottle of ZDDP with no issues.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
Re: Zinc Additive
[Re: autoxcuda]
#542337
12/02/09 03:11 PM
12/02/09 03:11 PM
MoparJ
Simi Valley, CA
Justin I have additive for flat tappet cams I sell to shops that do older cars and the guys at Engle Cams would send customers over to me too.
I can take care you.
Sounds good, Steve. I am going to start using the Delo 400 15w40 oil that my dad gets plenty of and I could mix the additive with it for a little spike of help.
Re: Zinc Additive
[Re: hooziewhatsit]
#542338
12/02/09 03:14 PM
12/02/09 03:14 PM
MoparJ
Simi Valley, CA
The last time I looked up the datasheet for Delo online, it had plenty of Zinc and Phosphorus by itself.
It's what I run in my 318.
I think it has 1200 ppm, but I am not sure if it had lowered or not.
I would like to use that as a base oil in my 318 and 383, as both have after market flat tappet cams.
