Leaking intake manifold gasket? #542310
12/01/09 07:40 PM
12/01/09 07:40 PM
New Jersey, USA
JeffRacerG Offline OP
New Jersey, USA
Took my Road Runner with a 383 over to an old time mechanic today to get his opinion on an engine problem. Runs great with no smoke from the tail pipes, but pushes a steady stream of smoke (not puffing) out of the breather hose. When I block the breather hose, the idle picks up quite a bit. Old time mechanic told me the intake manifold gasket is leaking under the valley pan and into the crankcase. Any thoughts before I pull it a part as my winter project?
Re: Leaking intake manifold gasket? [Re: JeffRacerG] #542311
12/01/09 08:30 PM
12/01/09 08:30 PM
Az
Crizila Offline
Crizila  Offline
Az
From one old time mechanic to another, I would have to agree.
Fastest 300
Re: Leaking intake manifold gasket? [Re: JeffRacerG] #542312
12/01/09 09:09 PM
12/01/09 09:09 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
I would try a new pcv valve first. Why would a leaking intake gasket be forcing air "out" of crankcase?
Re: Leaking intake manifold gasket? [Re: buildanother] #542313
12/01/09 09:22 PM
12/01/09 09:22 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Try the pCv first but as a winter project for a intake manifold gasket replacement it could be a short winter because it can be done in a couple of hours including a beer break. B/RB engine intake R&R's are a piece of cake. No coolant to worry about or anything.
Re: Leaking intake manifold gasket? [Re: buildanother] #542314
12/01/09 09:28 PM
12/01/09 09:28 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
it wont.
