What did I do on this run? #542290
12/01/09 06:50 PM
12/01/09 06:50 PM
San Francisco Ca
SCATPK Offline OP
SCATPK  Offline OP
San Francisco Ca
Took my car to the track the other day and this happened on my second run. It seems my car rolled forward and I knocked out the top yellow light, but when I did finally make it down the track and recieved my slip it had no information for my lane on it. Was there a malfunction or was it just my dumb azz?
http://s172.photobucket.com/albums/w29/Jeepmon/Video/?action=view&current=Herb.flv
Re: What did I do on this run? [Re: SCATPK] #542291
12/01/09 06:53 PM
12/01/09 06:53 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Sounds like a DQ to me. Sears Point? (I know it's Infineon now, just can't do that...)
Re: What did I do on this run? [Re: topside] #542292
12/01/09 06:56 PM
12/01/09 06:56 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
What did he do?? I see him sitting there, the bottom stage light went out and the red lit up..
Re: What did I do on this run? [Re: topside] #542293
12/01/09 07:01 PM
12/01/09 07:01 PM
San Francisco Ca
SCATPK Offline OP
SCATPK  Offline OP
San Francisco Ca
It was not a time run so not sure if that matters. I think I just blew it by rolling forward and then killing the engine just a bad run all around. Actually I am a bit embarrassed to post it but wanted to get some opinions.
Here is a better run.
http://www.youtube.com/watch?v=N-EwO2XCvIM
Re: What did I do on this run? [Re: SCATPK] #542294
12/01/09 07:10 PM
12/01/09 07:10 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
I still think you rolled backwards out of the beam and I would guess it was caused by the stiff headwind at the same time your came off the brakes..
Maybe its time to use the line lock while your waiting on the green..
Re: What did I do on this run? [Re: Jeepmon] #542295
12/01/09 07:25 PM
12/01/09 07:25 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Probably staged really shallow and then stteled out the beam. Why they red lite you so fast is beyond me.
Re: What did I do on this run? [Re: topside] #542296
12/01/09 07:41 PM
12/01/09 07:41 PM
Renton Washington
Triple Threat Offline
Renton Washington
You rolled backwards out of the beam when the starter hit the button. Time slip probably says LB3A right?
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: What did I do on this run? [Re: Triple Threat] #542297
12/01/09 08:06 PM
12/01/09 08:06 PM
San Francisco Ca
SCATPK Offline OP
SCATPK  Offline OP
San Francisco Ca
Time slip and no information for my lane!
Re: What did I do on this run? [Re: SCATPK] #542298
12/01/09 08:14 PM
12/01/09 08:14 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Are you sure it rolled backwards? To me it looks like after you were fully staged with both bulbs lit you let off the brakes(brake lights went out) and you simply rolled forward for a redlight.
Nice car by the way!
Re: What did I do on this run? [Re: ProSport] #542299
12/01/09 08:25 PM
12/01/09 08:25 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
If he rolled forward, wouldnt the top staging light go out before the 2nd one?
Re: What did I do on this run? [Re: Jeepmon] #542300
12/01/09 08:28 PM
12/01/09 08:28 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Exactly why I think he rolled back.
Re: What did I do on this run? [Re: WILD BILL] #542301
12/01/09 10:35 PM
12/01/09 10:35 PM
Gilbert, AZ
Aspen7695 Offline
Aspen7695  Offline
Gilbert, AZ
You rolled back out of the stage beam. That is an automatic red light. Once the tree is activated you get an instant red. You got no time because the system sees your action as if you left before the tree is activated.
Raul
Re: What did I do on this run? [Re: Aspen7695] #542302
12/01/09 10:52 PM
12/01/09 10:52 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Even a red should give the times and speed info.
Re: What did I do on this run? [Re: MoparforLife] #542303
12/01/09 11:30 PM
12/01/09 11:30 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Looks like his red light came on before the other side tree started coming down.
That would be consistant with being DQ'd
Is this a stick shift car or automatic?
Re: What did I do on this run? [Re: WILD BILL] #542304
12/02/09 12:49 AM
12/02/09 12:49 AM
petaluma,ca. u.s.a.
west Offline
west  Offline
petaluma,ca. u.s.a.
a mouser ran across your beams
Re: What did I do on this run? [Re: WILD BILL] #542305
12/02/09 01:01 AM
12/02/09 01:01 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
As already pointed out the car moved out of the beams backwards. The reason for the instant red was it was the other car was staged, all four bulbs on, no option when someone moves backward or totally out of the beam but to DQ them. Just the way it is.
Wish I could have gotten over to chat Herb. Always enjoy shooting the breeze with you and admiring that cool GTX you have. BTW the linelock idea is a very good one for the launch.
