3-speed wiper questions... #541847
12/01/09 02:05 PM
12/01/09 02:05 PM
Norwalk, Ohio
sycboi Offline OP
sycboi  Offline OP
Norwalk, Ohio
I bought a 3-speed wiper motor from Jules. My car is a '70 Dart and came stock with a 2-speed set-up.
Besides a 3-speed switch what else do I need to convert my car?
3-speed switch harness to main dash harness?
Different arm that bolts to the motor drive stud?
Any help is appreciated...
-Michael
SuperBeast
An enforcer for the Mopar Mafia!
Re: 3-speed wiper questions... [Re: sycboi] #541848
12/01/09 02:54 PM
12/01/09 02:54 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
the harness is the same , the switch makes it work , but there is an external wire that should be on the switch that jumps between terminals on the rear. Also the arm off the drive stud is different .
Re: 3-speed wiper questions... [Re: JohnRR] #541849
12/01/09 05:15 PM
12/01/09 05:15 PM
Norwalk, Ohio
sycboi Offline OP
sycboi  Offline OP
Norwalk, Ohio
I was just told the harness is different and the little arm attached to the drive stud is the same.
Now I am really confused...
-Michael
SuperBeast
Re: 3-speed wiper questions... [Re: sycboi] #541850
12/01/09 05:41 PM
12/01/09 05:41 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Maybe it is ? I'm going by a B body , the dash harness is the same , the harness from the motor to the bulkhead is different , I would ASSuME A body is the same ?
Re: 3-speed wiper questions... [Re: sycboi] #541851
12/01/09 09:06 PM
12/01/09 09:06 PM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
-Michael
The harness under the dash is the same.The harness on the motor is different.The crank that attaches to the motor is different and is a-body only.I have several of the cranks PM me if you need one
NS1AAR
Re: 3-speed wiper questions... [Re: ns1aar] #541852
12/01/09 10:28 PM
12/01/09 10:28 PM
Montreal,Quebec,Canada
JulesdaWiperman Offline
super gas
super gas
ns1aar is correct.
You will need a crank arm ending with part number 272.
You will need a 3 speed switch. The dash harness remains the same.
You will need a tan colored nylon bushing instead of the 2 speed black one.
The 3 speed wiper motor black plug will plug into the same pod the 2 speed plugged into
on the firewall bulkhead.
Jules
Re: 3-speed wiper questions... [Re: JulesdaWiperman] #541853
12/01/09 10:36 PM
12/01/09 10:36 PM
Norwalk, Ohio
sycboi Offline OP
sycboi  Offline OP
Norwalk, Ohio
Thank you Jules, and others...
-Michael
SuperBeast
