who makes this solid lifter #541702
12/01/09 03:15 AM
12/01/09 03:15 AM
Gettysburg Pa
roadrunnerreds Offline OP
Gettysburg Pa
i have a new set of solid lifters and i have not seen this type before who makes a solid body lifter? thanks Brad
Re: who makes this solid lifter [Re: roadrunnerreds] #541703
12/01/09 03:21 AM
12/01/09 03:21 AM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
Is that a comp full body solid???
I only run full body solids, and the new SMS (Beck) types im running now are full solid as well.
No pushrod oiling.
Re: who makes this solid lifter [Re: quick77rt ] #541704
12/01/09 03:56 AM
12/01/09 03:56 AM
Oh
His and Her 69's Offline
Oh
That looks like mine that I got from Comp Cams this fall. I needed a solid one as my pushrod went thru the top of my mopar solid lifter.
So I believe it is a Comp Cams Lifter.
David
Re: who makes this solid lifter [Re: His and Her 69's] #541705
12/01/09 08:31 PM
12/01/09 08:31 PM
Gettysburg Pa
Gettysburg Pa
Yes they are solid body lifter.any beneifits over other lifters? thanks Brad
Re: who makes this solid lifter [Re: roadrunnerreds] #541706
12/02/09 04:34 AM
12/02/09 04:34 AM
Oh
Oh
They are heavier but they won't break easily.
Like I said mine pushed the pushrod right thru the top of the lifter plunger. Comp cams recommended these as the fix to my issue.
Just my
David
