What year ? 2944450 wheel #541487
11/30/09 08:33 PM
11/30/09 08:33 PM
PNW
Beebuzzn Offline OP
Beebuzzn  Offline OP
PNW
Trying to idenify year of this #450 wheel. Very light stamping M? 8 21 But on the back side it has small white paint mark ? can this help idenify year ? The wheel was in trunk of a 72 challenger I had.
Re: What year ? 2944450 wheel [Re: Beebuzzn] #541488
11/30/09 08:53 PM
11/30/09 08:53 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
The stamping should be:
M1
0
for 1971
and
M1
9
For a 1970
M = Motorwheel company
1 = Plant #
digit under the M indicates year it was made
Your "M" stamping looks like a double hit or a mis-stamp? The date is also stamped inside the rim area covered by the tire, look there to confirm. It's also possible that it has no year date stamp, some VERY early 1970 production wheels came that way. If you don't need it I know a guy who needs an early on like that for his super early build date car, PM me and I'll give you his contact info.
Re: What year ? 2944450 wheel [Re: Beebuzzn] #541489
11/30/09 09:00 PM
11/30/09 09:00 PM
Fort Workin Tx
Day2Runner Offline
Day2Runner  Offline
Fort Workin Tx
M= plant
8=month
21=date
look closer around the the bottom of the M for the year
if its a 0 its for a 70 1 its a 71
its a shame those are not worth much I do have a farm trailer I need a good wheel for it.would you be interested in trading it for a dog dish hub cap??
Re: What year ? 2944450 wheel [Re: Beebuzzn] #541490
11/30/09 09:05 PM
11/30/09 09:05 PM
PNW
Beebuzzn Offline OP
Beebuzzn  Offline OP
PNW
picture of backside of wheel
Re: What year ? 2944450 wheel [Re: Beebuzzn] #541491
11/30/09 09:09 PM
11/30/09 09:09 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Looks like you'll need to get the tire removed to learn any more about that one.
Re: What year ? 2944450 wheel [Re: ScottSmith_Harms] #541492
11/30/09 09:20 PM
11/30/09 09:20 PM
PNW
Beebuzzn Offline OP
Beebuzzn  Offline OP
PNW
Thanks for the info. When I get a chance I'll dismount the tire to verify date.
Re: What year ? 2944450 wheel [Re: ScottSmith_Harms] #541493
11/30/09 09:25 PM
11/30/09 09:25 PM
Fort Workin Tx
Day2Runner Offline
Day2Runner  Offline
Fort Workin Tx
M1
0
for 1971
and
M1
9
For a 1970
1 = Plant #
Scott would the dates stamped on 390 rallyes be different than 15x7 steel 450s
9=70 or
0=70 ??
just askin THx
Re: What year ? 2944450 wheel [Re: Day2Runner] #541494
11/30/09 09:44 PM
11/30/09 09:44 PM
PNW
Beebuzzn Offline OP
Beebuzzn  Offline OP
PNW
I just went out and took another look and saw on the back side on the center hub area date was M59 also had 96 and a C I'm thinking that must be when the center part of wheel was made. How about date code for tire ? The Goodyear has a UA91G31 is this date info ? G could be 6
Re: What year ? 2944450 wheel [Re: Beebuzzn] #541495
11/30/09 09:53 PM
11/30/09 09:53 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Just start the money dance now..
Re: What year ? 2944450 wheel [Re: 1_WILD_RT] #541496
11/30/09 10:03 PM
11/30/09 10:03 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Day2,
Yes, that would be the same on your 390 wheel.
Original poster, it appears that you do have an early 1970 Wheel based on the info you last posted.
M = Motorwheel
5 = Plant #5
9 = 1969
and then the month and day stamped on either side of the valve stem as decoded by another poster above, August 21st.
Also, that tire looks like a good one, if the tread is nice and it's not weather checked that's a keeper as well. PS, don't clean the tire! Leave all the grease pencil markings etc. alone.
Re: What year ? 2944450 wheel [Re: Beebuzzn] #541497
12/01/09 08:19 AM
12/01/09 08:19 AM
uk
TiMopar Offline
TiMopar  Offline
uk
That's an early tire; the later ones had the size in white rubber....
Re: What year ? 2944450 wheel [Re: TiMopar] #541498
12/01/09 07:30 PM
12/01/09 07:30 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
hudson dont dismount it! leave it be...some idiot at the tire shop will ruin it! later dan
Re: What year ? 2944450 wheel [Re: ph23vo] #541499
12/02/09 02:51 PM
12/02/09 02:51 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
tire
U - 1969
A - August
9 - ??
1 - Akron, OH Goodyear tire plant
wheel center
M5/9 - Motor Wheel plant #5 (Canada) 1969
wheel hoop
2944450
M1/9 - Motor Wheel plant #1 (USA) 1969
8 -o- 21 * - Thursday, August 21st
You can see the top of the "9" in the first pic. I find it odd that the center is from CANADA and the hoop from USA.
Anyone have a "450" wheel they can look at to see if this is the norm?
Re: What year ? 2944450 wheel [Re: 6bblgt] #541500
12/02/09 04:32 PM
12/02/09 04:32 PM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
Dan
I looked at a couple of mine and yes, that is how they are on 2 that I just looked at.
Here are some pictures of my 10/14/69
I also looked at one of my 1-15-70's and it had M1 on the hoop and M9 on the center also.
Brad
Re: What year ? 2944450 wheel [Re: 6bblgt] #541501
12/03/09 03:48 PM
12/03/09 03:48 PM
PNW
Beebuzzn Offline OP
Beebuzzn  Offline OP
PNW
Thanks for all the info. Was out this morning in the garage and took a look at the 4 15" rallye wheels that came with the same car as the 450 wheel and there all date coded M19 8 12 So I'am thinking maybe these wheels all came on the same car and the 450 wheel was the spare ? The tire being a F60-15 on the 450 wheel would most likely indicate these were off a B-body ?
Re: What year ? 2944450 wheel [Re: Beebuzzn] #541502
12/03/09 03:58 PM
12/03/09 03:58 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
Yes, they had to have come from a '70 B-body since 15" wheel equipped E-bodies could only have a space saver spare.
'70 Super Bee 440 6 pack 4-spd 4.10 Dana N96 EB5
‘70 Super Bee 440 6 pack 4-spd 3.54 Dana FC7
‘70 ‘Cuda 440+6bbl 4-spd 3.54 Dana N96 EB5 V1W
