E locker vs. Spool? #541009
11/30/09 01:49 PM
11/30/09 01:49 PM
Midwest
RSNAKE Offline OP
RSNAKE  Offline OP
Midwest
I building a car that I expect to run in the 9's on slicks and will weigh around 3,800 lbs.
How much slower will the car be using an Eaton E-Locker vs. a spool in a Dana 60 rearend? How much will the additional weight and rotating mass slow the car down?
Does anyone have experience with an Eaton E-Locker in this level of application durability wise?
Re: E locker vs. Spool? [Re: RSNAKE] #541010
11/30/09 04:39 PM
11/30/09 04:39 PM
Locomotion Online content
Locomotion  Online Content
I have no personal experience with a locker, but basically if you do any street driving, a locker would be a good idea. However, I'm sure a couple of people do use a spool on the street on a limited basis. But it would be suicide in the rain.
If it is strip only, I can't think of any reason why you should not go with a spool. I'm sure a spool is more durable than any locker, less expensive and why carry the weight? And with a Dana 60 spool, you can upgrade to 40 spline axles for extra long-term insurance. Not sure if a locker would have that option.
Re: E locker vs. Spool? [Re: Locomotion] #541011
11/30/09 09:28 PM
11/30/09 09:28 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I run a Detroit Locker in my 63 because it is a street car and it works great. But I only run mid 11's and my car weighs just over 3700 lbs with me in it. I agree if it is race only I would use the lighter spool. Ron
Re: E locker vs. Spool? [Re: 383man] #541012
11/30/09 09:32 PM
11/30/09 09:32 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
With a 9 second car even if you do drive it on the street I bet its not enough to warrant the locker. I would go with the spool as its the most simple and less likely to fail.
68 Barracuda Formula S 340
Re: E locker vs. Spool? [Re: RSNAKE] #541013
12/01/09 09:29 AM
12/01/09 09:29 AM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
I ran an E-locker in my 3800# ProStreet 71 Charger in 2004. First time I forgot to turn it off at the top end of the track and made the corner to the return road it broke internally. I told an Eaton rep about it at PRI and he said he did not recommend their unit for drag racing. The torque of large slicks going around a corner on a sticky track was too much for the E-Locker.
I am currently setting up a 3600# 70 B-Body with 1500hp twin turbos as a "street car". So I called ARB a few weeks ago and inquired about their air locker unit and was called back by both the head of marketing AND the head of the tech department, Both said they DID recommend their unit for racing and that it would hold up to something like 35,000 Ft pounds of torque. So I am getting setup as a dealer for them (through ProMax Carbs). If you need more info let me know as I will be talking to them directly in 2 weeks at the PRI show.
Scott
Re: E locker vs. Spool? [Re: ProStDodge] #541014
12/01/09 09:35 AM
12/01/09 09:35 AM
robin hood country
deaks Offline
deaks  Offline
robin hood country
How many types of 8-3/4 locker are there and are some stronger than others.
Mick
Re: E locker vs. Spool? [Re: deaks] #541015
12/01/09 11:27 AM
12/01/09 11:27 AM
The Wet Coast, Canada
megajoltman Offline
megajoltman  Offline
I will be running a normal Detroit locker in my 60. I have never broke on yet, little noisey on corners but I do not autocross my car.
1969 Dart 383/727/D60
CTD Ram 4x4 Mega Cab
Procharged 350Z
Re: E locker vs. Spool? [Re: megajoltman] #541016
12/01/09 03:51 PM
12/01/09 03:51 PM
Windsor ,Ca.
K
Keith Richards Offline
K
Windsor ,Ca.
Dr Diff built my 60 with a Detroit Locker and after a year and 100+ mid 10 sec. runs has held up great.
Re: E locker vs. Spool? [Re: Keith Richards] #541017
12/01/09 08:59 PM
12/01/09 08:59 PM
ProStDodge Offline
ProStDodge  Offline
In case there is any confusion, the E-Locker RSNAKE ia reffering to is an electric locking system which can be locked solid as a spool or unlocked to operate as a posi unit with the flip of a switch on the dash.
Weight wise, it was MUCH heavier than a spool, but I did not notice any power loss from the rotating assembly. I installed it after having the ladder bars fatigue and break from driving 18.5 tires with a spool on the street.
The ARB Locker I was refering to is a similar unit, only it requires an air supply to lock the unit, and is "open" when unlocked. They are more commonly used in 4x4 trucks for rock crawling.
The Detriot locker is a mechanical posi type unit and does not fully lock a rear end. There have been instances, particuarly in 4-speed cars, where the Detroit unit can create an unequal power distribution when power is first applied or between shifts. I ran one in a 383 4-speed car and every shift the car moved a few inches right before it locked again. Had an Automatic car with the same gears set (8-3/4) and it ran straight.
And if anyone can make a Detroit locker work, it would be Dr.Diff
Re: E locker vs. Spool? [Re: ProStDodge] #541018
12/01/09 10:54 PM
12/01/09 10:54 PM
Midwest
RSNAKE Offline OP
RSNAKE  Offline OP
Midwest
Scott - Am I understanding you right in saying you switched from a spool to an E-locker and now to an ARB locker? You have not noticed any change in ET due to any of these changes (before the E-locker broke)?
I believe the Eaton E-locker is an open diff when not engaged. The Auburn ECTED has an electric lock function and is a posi when not engaged.
Re: E locker vs. Spool? [Re: RSNAKE] #541019
12/02/09 05:35 AM
12/02/09 05:35 AM
ProStDodge Offline
ProStDodge  Offline
I did not notice an ET difference switching from the spool to the E-locker, and it was definitely a posi when unlocked. The car was running consistant 11.0's on motor, and 10.10 with a hit of NOS.
The ARB unit is going in a new project.
Re: E locker vs. Spool? [Re: ProStDodge] #541020
12/02/09 09:02 AM
12/02/09 09:02 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
ARB has a great reputation in the four wheel drive world. Most any problems people have with them involves the air lines and not the unit itself. Since a race car doesn't have alot of suspension travel and ideally stays out of the mud the air lines should be cake.
My understanding of the auburn echted is its a limited slip all the time, it never fully locks it just becomes a "really stiff" limited slip unit. It gets alot of mixed reviews from the jeep forums I am on.
