Re: SS Springs for street car
[Re: AndyF]
#540761
11/30/09 08:26 AM
11/30/09 08:26 AM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
I used a pair of left side springs( or was it the right side ones?) on my '68 convertible A-body. Either way, they sit level and ride & handle great.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: dustergirl340]
#540763
11/30/09 08:58 AM
11/30/09 08:58 AM
Posts: 1,012 indiana
mcmopars
indiana
too harsh a ride for me.but im getting old too.they work great but just stiff.imo
[Re: 5spdcuda]
#540766
11/30/09 11:08 AM
11/30/09 11:08 AM
Posts: 2,826 NY usa
540challenger
NY usa
There are a lot of opinions about what constitutes a "street" car. Clearly a lot of people have used SS springs on the street and are happy with the results. That said, they are not a very good choice. To expand on AndyF's comments, in addition to being biased they are also strongly cambered. In other words they are strongly arched. This results in two things. It raises the rear of the car which helps with tire clearance, but it also results in the spring not being flat at ride height. For best handling a rear leaf spring should be flat or nearly so at ride height. If the spring is arched at ride height then when you go around a corner weight transfer will cause the outside wheel move up relative to the body resulting in the spring becoming flat. This in turn forces that wheel to move rearwards thus resulting in a toe out condition at the rear wheel. A toe out condition at the rear results in oversteer. If cornering speeds are fairly low, you probably won't notice it. If they're high, you will notice it and you WILL be BUSY.
Very well said, i have been driving around with SS springs for a few years now and IMO it is not that too bad. Also if you do go with the SS springs make sure you get the correct length shock the stock ones are not long enough. Plus i don't remember which ones to order but if it mainly on the street you want to order two passenger side springs or driver not sure which one. the reason is if you get the passenger and driver side ones. The driver side of the car will be slightly higher then the passenger side as it is meant for drag racing preloading the driver side when under a load to help lauch the car.
[Re: 540challenger]
#540767
11/30/09 12:01 PM
11/30/09 12:01 PM
Posts: 21,081 Niles , Ohio
therocks
Niles , Ohio
I have them on my 65.They ride OK.Like Andy said the MP pieces dont work.His hangers that Mancini sells are a nice piece.MP couldnt even get the stud pattern correct.Rocky
Chrysler Firepower
