Page 4 of 16 1 2 3 4 5 6 15 16
Re: Dakota spindles on 73 clubcab done (almost) [Re: ramblebee] #54064
02/27/08 07:38 PM
02/27/08 07:38 PM
Amarillo, Tx
ramblebee Offline OP
Amarillo, Tx
Compared to this.
Re: Dakota spindles on 73 clubcab done (almost) [Re: ramblebee] #54065
02/27/08 07:40 PM
02/27/08 07:40 PM
Amarillo, Tx
Amarillo, Tx
And here is a overall pic of new stance.
Re: Dakota spindles on 73 clubcab done (almost) [Re: ramblebee] #54066
02/27/08 08:23 PM
02/27/08 08:23 PM
TN
'84 D150 Shorty Offline
Pickup Man
Pickup Man
TN
Fantastic thread! Quick question: There's been mention of the tie rod sleeve. What's wrong with the one on it now?
Re: Dakota spindles on 73 clubcab done (almost) [Re: '84 D150 Shorty] #54067
02/27/08 08:36 PM
02/27/08 08:36 PM
Amarillo, Tx
Amarillo, Tx
The factory Ram sleeve is a little short.The Dak steering arm is shorter than the Ram arm.Also the van outer tie rods are shorter than the Ram.In the pics the inner and outer rods are only threaded 3/4"-1" into the sleeve.If I can locate a sleeve about 2" longer Ill be home free.I havent had a chance to research it yet.Unfortunately working on my truck wont pay the bills. Ill get back on it this weekend
Re: Dakota spindles on 73 clubcab done (almost) [Re: ramblebee] #54068
02/27/08 09:33 PM
02/27/08 09:33 PM
Truckville, the capital of NY
85_Ram_4speed Offline
How far off is the ram tierod to the van/dakota as far as the joint shape/angle is concerned?
Could the stock ram one be used on the dakota dropped spindles without to much of a problem?
Outcast Dodge guy.
Re: Dakota spindles on 73 clubcab done (almost) [Re: 85_Ram_4speed] #54069
02/27/08 10:40 PM
02/27/08 10:40 PM
Amarillo, Tx
Amarillo, Tx
In this pic the stock Ram tie rod is on top, van on bottom.The dust boot doesnt come off the van tie rod,hence the c-clamp.The Dak/Van stud is larger by quite a bit.The The Dak/Van stud dimensions are- .621 at the small diameter and .703 at the large diameter.I dont have the deminsions for the Ram tie rods,but you can see the difference.
Re: Dakota spindles on 73 clubcab done (almost) [Re: ramblebee] #54070
02/27/08 10:45 PM
02/27/08 10:45 PM
Amarillo, Tx
Amarillo, Tx
Here is a picture of the Ram tie rod in the Dakota steering arm.The Ram tie rod stud is smaller in all areas.
Re: Dakota spindles on 73 clubcab done (almost) [Re: ramblebee] #54071
02/27/08 11:41 PM
02/27/08 11:41 PM
Parsons (SouthEast) Kansas
funkyjbp Offline
mopar addict
funkyjbp  Offline
mopar addict
41hemi, nice work!!
Flite727, kudos for the pics. i too (now) have them saved!
ramblebee, good work, turck looks great!!! thanks for R & D ing the tie rod ends. you saved me some head scratching later this year. i have made tie rod sleeves out of mild steel tubing. i bought stuff from the race shop that Jamie Mcmurray used to work at in Joplin MO. it was seamless and i had them tap both ends, one left and one right-handed threads. done this a few times on street rods. you have to run a jamb nut on the tie rod to snug them after adjusting them. I would investigate c-body sleeves. they use 11/16 threads which is what trucks have if i remember correctly. you can buy them new. a few suspension suppliers have them in aluminum too for around 50$ keep up the good work! JP in KS.
71 SWB, 413 77 SWB, 318 92 SWB, 5.2 magnum 79 Macho Short bed, 318 03 stratus coupe R/T too many others not on the road!
Re: Dakota spindles on 73 clubcab done (almost) [Re: funkyjbp] #54072
02/27/08 11:57 PM
02/27/08 11:57 PM
Amarillo, Tx
Amarillo, Tx
41hemi, nice work!!
So the c-body sleeves are the same id. and thread as the Ram? Man Im hoping the c-body sleeves work out. From looking at the pics they are long enough.That will definately be the easiest and cheapest way to go. I looked into the van sleeves they are 14 3/4" long . Im going to the parts store after work tomarrow.
Re: Dakota spindles on 73 clubcab done (almost) [Re: ramblebee] #54073
02/28/08 01:51 AM
02/28/08 01:51 AM
Sarcoxie, MO, USA
MoPar Jamie Offline
MoPar Jamie  Offline
Sarcoxie, MO, USA
Have you looked into 80s Truck tie-rods and sleeves? IIRC they changed in about '79 or '80. They are quite a bit longer than the 70s sleeves, not short like the ones you have now. I discovered this difference when I was tie-rod swapping on an '81 I used to have.
Have you got a referance for a stock-height truck yet? If not my '88 shorty is sitting stock right now. It has a Wee six though but it shouldnt make that much difference, though it may sit a bit higher. My tires in the pic are 235/70/16s, 29 inches tall.
- MoPar Jamie
1972 Fury III 4dr
1986 D-150 LWB Royal SE
Re: Dakota spindles on 73 clubcab done (almost) [Re: MoPar Jamie] #54074
02/28/08 08:10 AM
02/28/08 08:10 AM
I can measure the tie rod sleeve length off my '85 if you post the sleeve length on your '73.
Outcast Dodge guy.
Re: Dakota spindles on 73 clubcab done (almost) [Re: 85_Ram_4speed] #54075
02/28/08 08:22 PM
02/28/08 08:22 PM
Ok, on my '85, the tie rod sleeves are 9 5/8" long. I dont know what the thread size is, maybe someone else can chime in---maybe its possible if i do this swap i wont need tierod sleeves like on your '73.
Outcast Dodge guy.
Re: Dakota spindles on 73 clubcab done (almost) [Re: 85_Ram_4speed] #54076
02/28/08 08:49 PM
02/28/08 08:49 PM
Amarillo, Tx
Amarillo, Tx
85 Ram thanks for taking the time to measure your sleeves.I just left the parts store and its looking like the c-body sleeves are going to be perfect.85 Ram I actually had a set of your sleeves in hand at the store but they were too long.The Moog book shows 9.66". They took up all the adjustment in the tie rod ends.The c-body sleeves are 8.12" and should be fine.Moog part # ES440S.They are .687 on the adjustment end.Same as van and Ram sleeves.Here is the kicker no one in town has them in stock.They will be here at 7:30 tomarrow morning.The guys at O'reilly gave me a Moog master catalog I can cross refrence everything at home now.That was super cool of them.This is getting close fellas.
Re: Dakota spindles on 73 clubcab done (almost) [Re: ramblebee] #54077
02/28/08 09:01 PM
02/28/08 09:01 PM
Pacifica, CA
Devilbrad Offline
Devilbrad  Offline
Pacifica, CA
Are the New Yorker rotors and Ram calipers bigger than stock Dakota stuff??????
Re: Dakota spindles on 73 clubcab done (almost) [Re: Devilbrad] #54078
02/28/08 09:20 PM
02/28/08 09:20 PM
Amarillo, Tx
Amarillo, Tx
Yes they are bigger.I Cant recall offhand what diameter the Dak rotors are but its 10" and something.And If I remember correctly the Ram rotors are 11.75".Not positive on those #s, but I do know the Dak rotors are smaller.As far as Dak vs. Ram caliper size Im not sure.I do Know that the Ram caliper bracket will bolt directly onto the 91-96 Dak spindle.
Re: Dakota spindles on 73 clubcab done (almost) [Re: ramblebee] #54079
02/28/08 09:40 PM
02/28/08 09:40 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Depends on what year rotor than because I was informed the Dk rotors are Slightly larger than some. I dont remember what year but it was probably 83.
Re: Dakota spindles on 73 clubcab done (almost) [Re: ramblebee] #54080
02/28/08 10:03 PM
02/28/08 10:03 PM
I wonder what else is different because i tell ya, looking on mine, it looks if i flip the tie rod to the bottom side for those spindles that i would still need to lengthen my sleeves on my truck. Maybe there is alot more different between a '73 and an '85.
Outcast Dodge guy.
Re: Dakota spindles on 73 clubcab done (almost) [Re: 76dodgeboy] #54081
02/28/08 10:04 PM
02/28/08 10:04 PM
Amarillo, Tx
Amarillo, Tx
Ok I was off on the Dak rotor diameter.It is 11.315" for all 2wd 88-96. However the 91-96 Dak rotors are 6 lug. 88-90 are 5 lug.But as far as I can tell (and I might be wrong) all front disc equipped Rams 72-93 are 11.75.So the difference in rotor size is less than a half inch.
Re: Dakota spindles on 73 clubcab done (almost) [Re: 85_Ram_4speed] #54082
02/28/08 10:34 PM
02/28/08 10:34 PM
Amarillo, Tx
Amarillo, Tx
There could very well be some differences in tie rod ends from 72-93.Its just a matter of finding the adjusting sleeve that works.
Re: Dakota spindles on 73 clubcab done (almost) [Re: ramblebee] #54083
02/29/08 12:54 AM
02/29/08 12:54 AM
Amarillo, Tx
Amarillo, Tx
85 Ram 4 Speed post got me to wondering.So I did a little research.It looks like there was a tie rod change,both inner and outer in 79.According to my parts book( which I just noticed only goes up to 90) 72-78 inner and outer tie rods are 7.44" long.In 79 both inner and outer tie rods went to 5.16" long.Also the stud got larger in 79.But this shouldnt dicourage anyone,its just a matter of finding the correct tie rod and sleeve combo.This book is a awesome tool. If anyone needs help finding the right parts let me know.Or just go look it up at your local parts store.
