oil pan installation question #539790
11/29/09 12:28 AM
11/29/09 12:28 AM
California
fst340rt Offline OP
fst340rt  Offline OP
California
Working on my '72 340 .My question is about the tips of the side seals sticking out of both sides of the rear cap .Should I cut them flush with the sides of the cap before installing the oil pan? or are they supposed to be compressed at the time of the oil pan installation?
THank you in advance.
Re: oil pan installation question [Re: fst340rt] #539791
11/29/09 12:22 PM
11/29/09 12:22 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Cut them flush otherwise the pan end seal will not sit flush on the pan rail surface. Pus a "SMALL" bead of sillycone at the cap to block intersection.
