Re: Rust removal recipe ! works great! cheap to make!!
[Re: varunner]
#539592
08/28/10 06:05 PM
08/28/10 06:05 PM
Posts: 3,957 West Coast, CA
Troy
West Coast, CA
Looks good but your going to want to remove the paint off the valance before you dunk it...it wont remove paint.
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
[Re: Troy]
#539594
08/29/10 02:04 PM
08/29/10 02:04 PM
Posts: 75,004 U.S.S.A.
JohnRR
U.S.S.A.
If you leave it in there long enough it will ...
[Re: JohnRR]
#539595
08/29/10 02:24 PM
08/29/10 02:24 PM
Posts: 20,539 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
Evaporust , I found some last night but it was just a small bottle , is this a concentrate , it didn't say anything on the bottle so this is probably a stupid question. If it's not I'd have to spend $100 to get enough to put anything like a valve cover in it
I used it to clean up my spindles and instead of pouring a ton of evaporust into a big container I put them in a big zip lock bag one at a time and filled the excess space with small river rocks. This allowed me to use alot less of the evaporust and still get the whole spindle submerged.
For a valve cover I would settle for cleaning it one side at a time rather than using a lot of fluid to do it all at once. I'd make a rectangular frame out of scrap wood just big enough to hold the object and then set a trash bag in it filled with 1/4" or so of evaporust and then just rotate the valve cover over every few hours.
You can clean sheetmetal with this stuff by making a dam out of clay and then pour the evaporust inside. When you done you can remove it with a suction bulb.
[Re: varunner]
#539598
01/05/11 10:42 PM
01/05/11 10:42 PM
Posts: 757 Northern VA
bulletpruf
Northern VA
I'm on my second batch. Works quite well for me. I put parts in when I get home in the evening and then pull them out the next evening after work. Garage is cold this time of year, and I don't have time after work to get the sandblaster going, so this way I'm able to a little bit during the week.
Scott
Please Check Out My YouTube Channel for Vintage Musclecar and Truck Rescues and Builds -- https://www.youtube.com/@THEBULLETPROOFGARAGE/videos
[Re: varunner]
#539601
01/07/11 02:33 PM
01/07/11 02:33 PM
Posts: 331 Northeast
edl
Northeast
Framing square and clamps turned out pretty good. Rear valance needed to be flipped over, it'll come out tomorrow.
[Re: generallee6901]
#539602
01/09/11 10:59 PM
01/09/11 10:59 PM
Posts: 7,538 Albany, NY
67SATisfaction
The member whose name is actually Art
Albany, NY
Glad to find this thread is still active and it's great to see what you all are doing with it. I was reminded of it just recently: My 7-year-old found this same mixture in a paperback science book for kids showing them how to turn tarnished pennies all shiny. It explains that the acetic acid in vinegar changes into hydrochloric acid when it mixes with the salt. Same as stomach acid. No mention of the lemon juice. He drops a penny in and 10 seconds later it's shiny. I will use it on a bunch of nuts, bolts, brackets. If it hasn't been discussed yet, one way to neutralize the acid is to rinse the parts in a mix of baking soda and water. -Art
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
[Re: 67SATisfaction]
#539603
01/10/11 08:59 PM
01/10/11 08:59 PM
Posts: 8,249 fredericksburg,va
cudaman1969
fredericksburg,va
couple of questions, jamesdart said his batch lost its strength after three days,anybody else had this problem? would putting in a sealed container help? i know my 22 dollar a gallon of evapo-rust did, reused three times.good for bolts, anything larger would cost a fortune. would heating up the mixture help(floating tank heater)we use one for the horse tank. as far as the cost, use the good stuff for delicate parts, the vinegar for the other, a no-brainer.
