Driveshaft question #539142
11/28/09 03:38 PM
11/28/09 03:38 PM
Denmark, Helsingor
AAR70 Offline OP
AAR70  Offline OP
Denmark, Helsingor
A cuda driveshaft with part # 2781928 ,is there anyone who knows what cuda model itīs came from ?
Re: Driveshaft question [Re: AAR70] #539143
11/28/09 03:50 PM
11/28/09 03:50 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Number is not found in 1969 or 1970 MOPAR Parts Catalog.
Number is not found in GG's "white books".
Number is not found in Hollander interchange mannual.
It would be a late '60s part number, are you sure it is correct?
Is the numbwer on the driveshaft or on a parts tag?
Can you measure it & get dimensions?
Re: Driveshaft question [Re: AAR70] #539144
11/28/09 04:30 PM
11/28/09 04:30 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
That is the casting number for the aft u-joint cap. Check the other end and you will find a different number for the transmission end.
The number you need is stamped in the tube and will probably be within 12-18" from either end.
It will look like this, the date code is nearby.
Re: Driveshaft question [Re: 6bblgt] #539145
11/28/09 04:34 PM
11/28/09 04:34 PM
Denmark, Helsingor
AAR70 Offline OP
AAR70  Offline OP
Denmark, Helsingor
The seller say the driveshaft came from a 1970 cuda 340 3 sp manuel , the dimensions is : lenght 43,85 inch, diameter 3 1/4 ,u-joints is 7260 in front and 7290 rear .
Re: Driveshaft question [Re: AAR70] #539146
11/28/09 04:42 PM
11/28/09 04:42 PM
Snoopy Offline
Snoopy  Offline
Here is the number you need.
AAR - 2883769
AAR - 43.85" - 7290/7260
Re: Driveshaft question [Re: Snoopy] #539147
11/28/09 04:42 PM
11/28/09 04:42 PM
Denmark, Helsingor
AAR70 Offline OP
AAR70  Offline OP
Denmark, Helsingor
Thanks,
Re: Driveshaft question [Re: AAR70] #539148
11/28/09 07:17 PM
11/28/09 07:17 PM
Snoopy Offline
Snoopy  Offline
Lau,
Can you post the casting number from the transmission end?
