1/4 turn fasteners #538562
11/27/09 11:15 PM
11/27/09 11:15 PM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
I'm looking at hardware to mount my new lift off hood and I see these type of fasteners come in different lengths. What dictates which length one you need
Re: 1/4 turn fasteners [Re: flatiron] #538563
11/27/09 11:20 PM
11/27/09 11:20 PM
The distance to the hold down spring and the mounting bracket location for the hold down spring I had to notch my hood sides to use the .500 Dzuz fasteners
Re: 1/4 turn fasteners [Re: Cab_Burge] #538564
11/28/09 07:38 PM
11/28/09 07:38 PM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
Do you think the ones with the .650 shank will work better? Not as much trimming needed
Re: 1/4 turn fasteners [Re: flatiron] #538565
11/28/09 11:01 PM
11/28/09 11:01 PM
I ordered a kit of ten Dzuz fasteners and Moroso mounting plates for .500 depth, they worked on the four fronts and the two in the back (I also used the stock hinges on the rear corners, I didn't want a lift off hood anymore) without any notching, the two on each side required notching the sides of the fibreglas hood, no big deal. As far as the .150 differences in depth on the .500 versus the .650, it wouldn't have made enough difference on the sides to make it worthwhile to switch to the .650 Dzuz fasteners and plates. your situation mad ebe different than mine, I would look closely before deciding on which type or types to use, look twice, buy once You may need more than one depth and style
