440 engine heads/springs #537855
11/27/09 01:47 AM
11/27/09 01:47 AM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
I have an original 1970 date coded 440 engine out of a Chrysler New Yorker. Are the heads and springs the same as a commando 440? I know the cam is different.Any info is helpful.
Re: 440 engine heads/springs [Re: roy2345] #537856
11/27/09 02:24 AM
11/27/09 02:24 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
heads are the same the springs are not !
hp motors had a redspring with a inner flat damper !
Re: 440 engine heads/springs [Re: calrobb2000] #537857
11/27/09 02:38 AM
11/27/09 02:38 AM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
so the valves are the same size? I put HP manifolds on the engine. The intake is the same too as the commando? Will the springs need changing if I put a mild cam in the motor?
Re: 440 engine heads/springs [Re: roy2345] #537858
11/27/09 02:51 AM
11/27/09 02:51 AM
Riverside, Ca
R70RUNNER Offline
R70RUNNER  Offline
Riverside, Ca
Valves are the same size...Intake my be diff number? but you won't notice a diff in perf. Hp exhaust fits fine. Please define "mild cam" When in doubt? change the springs to cam manuf. recommendation
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
Re: 440 engine heads/springs [Re: R70RUNNER] #537859
11/27/09 09:17 AM
11/27/09 09:17 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Springs are cheap and using 40 year old springs even on a stock cam makes no sense??
Just to give an idea comp performance springs at Mancini racing
http://chucker54.stores.yahoo.net/comcambrbhig.html
Re: 440 engine heads/springs [Re: Dodgem] #537860
11/27/09 10:55 AM
11/27/09 10:55 AM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
ok...can replacing the springs be done without pulling the heads?
Re: 440 engine heads/springs [Re: roy2345] #537861
11/27/09 11:21 AM
11/27/09 11:21 AM
scratchnfotraction Offline
yes,they can be swaped with head on engine
short piece of rope in the sparkplug hole,hand crank it till the rope is compressed against valves to hold them
hand crank spring compresser and swap the seals while your there is a good idea
IMO,never liked the air hose trick,to easy to drop the valve,,been there and had to pull the head..might have helped to have the piston at top..which I did not do
I used a KD tool hand crank compresser from napa..about 60$
new spring to match cam is a must and good insurance
Re: 440 engine heads/springs [Re: scratchnfotraction] #537862
11/27/09 11:31 AM
11/27/09 11:31 AM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
thanks for the education guys. Will changing the seals and springs help with being able to be burn unleaded gasoline better? What do they mean about hardened seats? Sorry if I got off subject
Re: 440 engine heads/springs [Re: roy2345] #537863
11/27/09 01:09 PM
11/27/09 01:09 PM
no,seals,seal the valve stem were it slides in the vlave guide to keep oil from working down the stem into the comb chamber,where it burns and cause the engine to smoke.
those heads have the hard seat already for unlead gas..
look for pits on the exhast valve edge and the seat part in the head that the valve seals off on,pitts cause it to leak.
before you take the valve out,set it up and pour some water in the port to see if the valve leaks
thats 1 way to see if it needs a valve job.
which they regrind the seat and valve edge with 3 angles or more,to seal it and not leak. doing a valve job at the machine shop..
with the spring off,see if you can move the valve stem tip back and forth.that checks the wear on the valve guide..
Re: 440 engine heads/springs [Re: scratchnfotraction] #537864
11/27/09 01:17 PM
11/27/09 01:17 PM
OH! my bad,I see its a 70-440 new yorker
what heads are on it?,it could have been swaped since 1970
I was thinking #452 heads from 75 and later
dont think the 70 had hard seats yet.
Re: 440 engine heads/springs [Re: scratchnfotraction] #537865
11/27/09 08:46 PM
11/27/09 08:46 PM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
nah all original running engine..heads are what came with it. I was wondering what is different on the engines to get the Hpower
Re: 440 engine heads/springs [Re: roy2345] #537866
11/28/09 01:56 PM
11/28/09 01:56 PM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
is it safe to do a cam,lifters, timing chain, valve springs and not do a valve job? Does Heads have to be pulled to replace the hardened seats?
Re: 440 engine heads/springs [Re: roy2345] #537867
11/28/09 02:24 PM
11/28/09 02:24 PM
yes,they have to come off for seats to be milled and pressed in.
yes,you can do the cam,lifters,t-chain,springs,seals,with them on the engine
I have done a few with out a valve job
with the rockers and shaft removed use a straight edge across tips of valves
if any are sticking up higher than others, then most likly it needs a valve job cause the valves are sunk into the heads,IIRC
Re: 440 engine heads/springs [Re: roy2345] #537868
11/28/09 02:45 PM
11/28/09 02:45 PM
You have 906 heads which didn't have (& didn't need to have) hardened seats as '70 gas had lead in it but there hasn't been much or very little lead used since the mid 70's so between that & the 40 yrs of use I'd sure think the heads need some major attention especially if you are planning on some serious hot rodding. I see heads for cheap all the time and you might get a set of later hardened seat ones & go thru them to have them ready & minimize your down time & if you want to stay original which I didn't get the feeling you did, you could redo your 906's w hardened seats on the ex side & as said new springs also to go with a new cam/lifters but then most likely the valves are also probably shot esp the ex's as they run hotter and with the amt of $$ that this endeavor will up taking to do it right you might consider some stealths s
Re: 440 engine heads/springs [Re: RapidRobert] #537869
11/28/09 05:04 PM
11/28/09 05:04 PM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
wow! I already have 906 Heads. engine has 86,000 miles on it. But like u said it is 40 years old. The car runs strong now. I just wanted to get that additional pop like the magnums or commando engines. In essence, I have a Magnum minus the Cam?
Re: 440 engine heads/springs [Re: roy2345] #537870
11/28/09 05:24 PM
11/28/09 05:24 PM
does it have an AVS carb? and all oe AVS's were emission carbs. I'd suggest an eddie strip kit to richen it up (fill the domed metering rod caps w epoxy to make them flat) and different dist springs/shorten the slots which will give you the most bang for the buck & if the long block is healthy or after you get it healthy I'd attack the most restricted area of the whole package 1st which is usually the manifolds and restricted exhaust.
Re: 440 engine heads/springs [Re: RapidRobert] #537871
11/28/09 05:32 PM
11/28/09 05:32 PM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
ok. I have put the HP manifolds on already and changed the carb.I have a holley 750 dual lone vaccum secondaries. I changed from points to Electronic ignition with another distributor. Now I do experience a little ping when i really get down on it and I was told to adjust the screw inside of the vaccum advance. The other exaust is from the 318 i had in the car. I spliced into that system. from the manifolds is 2 1/5 inch piping to middle ways of the car. from that splice to the rear is 2 inch piping with turbo mufflers. I have plans to finish the exaust off with 21/5 pipe and Magna flow mufflers. However not 1oo% sure on mufflers. Recommendations? Sorry I have gotten of the topic. You are really helping me my mopar friend. Any advice welcomed.
Re: 440 engine heads/springs [Re: roy2345] #537872
11/28/09 05:51 PM
11/28/09 05:51 PM
The ex is way restricted. those 68-70 Hp manifolds flow pretty good for manifolds but I'd suggest 2&1/2" MANDREL pipes all the way back (w an X connector)and free flowing muffs and some resonators in the rear to continue with keeping the noise down. What is your initial and total timing? An overview, you'd want to tune the initial for the cam then the slot length for 36-38 total (vac adv disconnected) then the springs for just below the pinging point at WOT then plug in the vac adv & stay just under the pinging point at part throttle. Any pinging is very destructive so for now (depending on what your initial is & I am assuming it is very conservative ~10btdc??) you might stick a 3/32" allen wrench into the vac adv & turn it 2 full turns CCW & try it out.
Re: 440 engine heads/springs [Re: RapidRobert] #537873
11/28/09 06:01 PM
11/28/09 06:01 PM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
ok. I figured the exaust was not letting her breath totally. I gotta keep the HP manifolds but I'm doing the rest of the exaust like u said. But what are the resonators? How does that work? I guess I'll google that. lol what mufflers you recommend for this car? I DRIVE IT EVERY WEEKEND I CAN. Even during the week. So I want to let the young boys hear class but yet power.
Re: 440 engine heads/springs [Re: roy2345] #537874
11/28/09 06:05 PM
11/28/09 06:05 PM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
i didnt put a light on it. just set it by the pinging and best power while not dragging to crank while hot..
