Ah nutz. Wife called. '02 Intrepid in Limp mode
#53766
02/05/08 05:28 PM
02/05/08 05:28 PM
Posts: 8,430 St Charles MO
70Coronet500Vert
St Charles MO
3500 rpm at 45mph.
Taking it in. Any advice on what to look for?
Don't know codes yet. Guy at tranny shop said input or output sensor or possibly internal problem. Impossible to tell until he runs codes.
No matter how responsible he may seem, never give your gun to a monkey! 1970 Coronet Vert 1972 Charger 1974 Satellite Sebring Plus Sundance 2001 Ram 4x4 2002 Intrepid 2006 300C
Re: Ah nutz. Wife called. '02 Intrepid in Limp mode
[Re: 70Coronet500Vert]
#53769
02/05/08 07:02 PM
02/05/08 07:02 PM
Posts: 377 Michigan Troll
blk00rt
Michigan Troll
on some chryslers if you turn the key on and off 4 times without starting the engine it will run the codes for you. On the last time leave the key in the on position but do not start the car. All this has to be done within like 15 seconds or so.
Rob Dunn 1976 Dart Sport 360 2000 dakota RT 408 with 150 nitrous 2013 Dodge Ram 1500 Hemi 2009 Jeep Patriot
[Re: gtx6970]
#53771
02/05/08 08:14 PM
02/05/08 08:14 PM
Wifes speedo quit working, an the car went to limp mode, replaced the speed sensor which was external an back to normal.
[Re: MoparforLife]
#53774
02/06/08 07:33 AM
02/06/08 07:33 AM
Posts: 21,081 Niles , Ohio
therocks
Niles , Ohio
Is the speedo working? If not that is usually the speed sensor.Pulling the codes is the best way though.Rocky
Chrysler Firepower
#53775
02/06/08 09:46 AM
02/06/08 09:46 AM
70Coronet500Vert
St Charles MO
A brief update.
Last night we dropped it off at tranny shop. On the way there, it ran fine, shifted fine and in general behaved well. The fluid is full, red and not burnt or smelly.
I did the on-off-on-off-on thing and all it said was DONE. Tranny guy said tranny codes don't show up in that computer, or at least all of them. The check engine light is still on though.
I think it is a sensor.
#53776
02/06/08 12:48 PM
02/06/08 12:48 PM
70Coronet500Vert
St Charles MO
Code of 1776, Solenoid Valve stuck
I called the shop, he wants to drop the pan and "look around." The car drove fine for him and for his shop guy.
I told him do not drop pan, do not change fluid, just stop working on it. I haev terrible luck with trannys once they are opened up.
Whatcha yall think?
#53777
02/06/08 02:01 PM
02/06/08 02:01 PM
Posts: 535 Ohio
racerAL
Ohio
we've had a few of these come through the dealership w/ this code.there is a TSB out on this issue.it explains in detail what to look for and how to fix.TSB -21-008-04.it could be as simple as a cable adjustment....OR...contaminated valve body.take it to a dealer,have them take a look at it,IMO this will save u alot of running around and throwing parts at it.if the dealer is to expensive to fix,pay them the check out time and then maybe take it to ur tanny shop,w/ the exact info u need to get it fixed correctly.let me know if u need any info on the valve body regarding pricing,or avalability...Alan
-1967 Plymouth Satellite #3555 446 cid on E-85 best 1/4 et 10.577 @ 127.58 best 1/8 et 6.722 @ 100.68 best 60ft. 1.419
#53781
02/06/08 09:56 PM
02/06/08 09:56 PM
Posts: 535 Ohio
racerAL
Ohio
I don't think u can still get the V/B new,that part # supercedes (sp) to a re-man #,the only way to get it is a re-man #.the re-man V/B is readily available and is around $350.00.also,IMHO...the V/B is most likely your issue and not the solenoid.in my experience w/ LH cars that have this code (p1776) is caused by a contaminated V/B.normaly caused by ,dirt in the fluid gets into the V/B and locks that switch valve in the V/B, as earlier stated....hope this helped...keep us informed on how it goes...good luck ........Alan
[Re: racerAL]
#53782
02/07/08 08:50 AM
02/07/08 08:50 AM
70Coronet500Vert
St Charles MO
I got a quote for $387. It is the combined package with the solenoid pack and the valve body. Does not look too hard. I should be doing this Saturday.
I am going to do the whole thing. 5 new quarts of ATF4, filter, valvebody. Supposed to be 19 degrees, so that is right on par with this kind of repair. The only thing better would be if the truck needs a water pump, oh wait, it smells like it does......
Just for fun and for the folks at dodgeintrepid.net, i'm gonna photo as I go. I could post the pics here if anyone is interested. Hopefully by Sat afternoon, it'll back on the road.
#53783
02/07/08 10:17 AM
02/07/08 10:17 AM
70Coronet500Vert
St Charles MO
To any of you techs who have done this. Is the "Quick Learn" procedure required as the book states, after I have replaced the VB?
reason I ask is, I don't have a DRB tool. The book says to do it.
