Need radiator recomendation for 69 B body #537608
11/26/09 08:42 PM
11/26/09 08:42 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
Car is a 69 GTX. Engine will be 500 inch stroker from a 400 block. 4 speed car. I want to install a new aftermarket rad. What will fit without cutting and still cool this engine? What are you using in your car? Is aluminum the best way to go? Thanks
Re: Need radiator recomendation for 69 B body [Re: frank] #537609
11/26/09 08:53 PM
11/26/09 08:53 PM
Ohio
racerAL Offline
racerAL  Offline
Ohio
i'm using a aluminium rad that i bought off ebay...fits in stock location...try doin a search on ebay..
-1967 Plymouth Satellite #3555
446 cid on E-85
best 1/4 et 10.577 @ 127.58
best 1/8 et 6.722 @ 100.68
best 60ft. 1.419
Re: Need radiator recomendation for 69 B body [Re: frank] #537610
11/26/09 10:31 PM
11/26/09 10:31 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
i use a BE-COOL from summit.29X18.5"
Re: Need radiator recomendation for 69 B body [Re: blownzoom440] #537611
11/26/09 11:40 PM
11/26/09 11:40 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I bought a Summit rad. Haven't installed it but the application is the same as yours.
Re: Need radiator recomendation for 69 B body [Re: Stanton] #537612
11/27/09 09:13 AM
11/27/09 09:13 AM
IN
ahy Offline
ahy  Offline
IN
I'm using the "stock style" aluminum rad from Mancini on a similar type build. It fit well with stock hoses and cools great. Idling in 90+ weather with the AC on it will creep up to 185-190 max. I've matched it up with a MP high volume water pump slightly overdriven and a clutch fan.
Re: Need radiator recomendation for 69 B body [Re: ahy] #537613
11/28/09 03:41 AM
11/28/09 03:41 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I bought this Afco rad from Mancini. It has the side brackets on it and you just line it up and drill the holes in the bracket where you need them. The direct bolt in factory lool alike rad was $550. so I bought this one as it was $349. and it fit right in. Ron
Re: Need radiator recomendation for 69 B body [Re: 383man] #537614
11/28/09 04:05 AM
11/28/09 04:05 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I also run an aftermarket afco rad. Cools great, just had to drill some holes to make it fit.
