Re: To use a mid plate or limiters with motor plate
[Re: B G Racing]
#537473
11/26/09 05:44 PM
11/26/09 05:44 PM
Posts: 885 south louisiana
lowell66dart
south louisiana
If your installing a motor plate why not use a mid plate. Much easier to intall the engine and you'll be welding anyway. Just a couple of more tabs. It's also real nice when changing converters. I use a motor plate. mid palte and use my stock tranny mount as the limiter. No problems so far.
2021 Dodge 2500 4WD Cummins 2020 Challenger R/T Scat Widebody 2007 Charger R/T 5.7
[Re: B1KILLER]
#537475
11/26/09 06:33 PM
11/26/09 06:33 PM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
I have andys front plate with a .125 mid plate and solid trans mount. no limiters here. been 1.23 60'
BB, TT5,Procharged 3300lb Street Car 4.79/154
[Re: bigtimeauto]
#537477
11/26/09 06:50 PM
11/26/09 06:50 PM
Posts: 8,647 ELYRIA,OH
blownzoom440
ELYRIA,OH
i thaught that was a no no to have all 3 solid.
[Re: CrAzYMoPaRGuY]
#537479
11/26/09 06:56 PM
11/26/09 06:56 PM
bigtimeauto
Trophy Winner
Trophy Winner
My chassis is tied together very good with the cage i have. If you have a regular car without a killer cage you need some rubber somewhere.
[Re: CrAzYMoPaRGuY]
#537483
11/26/09 09:30 PM
11/26/09 09:30 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I would never run a solid trans mount! But that's just me.. I know guys who have.
I wouldnt run all 3 solid.... front plate, mid plate and a standard rubber trans mount with limiters (at least 1 limiter)... reason for not running all 3 solid is flex... go back to your old math class and you can have 2 points in a line but add a third and that one doesnt have to be on the same line even if it starts out there... you induce flex to the chassis and the third point is no longer on the same line... the weakest point is the trans tail shaft(most of the time it breaks at the speedo hole) As to the limiters... vertical plates dont add much to the fore/aft stability.... hence the limiters
[Re: bigtimeauto]
#537486
11/27/09 07:28 AM
11/27/09 07:28 AM
Posts: 4,852 KENTUCKY
69CHARGERMD
KENTUCKY
This is a shot of the work BondoBob did,,,limiter ,, motor ears,,,etc,,,when i had the tubular K frame done...
[Re: dvw]
#537489
11/29/09 12:27 AM
11/29/09 12:27 AM
Posts: 16,493 Canada
CrAzYMoPaRGuY
Canada
My car is still under construction. I used the two rear transmission tabs, but I machined them out for thin bushings. My front mountings are both bushed with polyurethane (I think) homemade bushings. (Street car)
CrAzYMoPaRGuY
