Re: is anyone running a set of 440source alum. heads?
[Re: 68_300_conv]
#537408
11/27/09 12:03 PM
11/27/09 12:03 PM
Posts: 21,068 Niles , Ohio
therocks
Niles , Ohio
I have them on my 12.5 440.Been on over 2 years street driving and some racing.I had new springs retainers and keepers on mine as I run a .588 solid cam with 4 speed.My machinist back cut the valves and cleaned them up some.He is a stickler for perfection and he was impressed with them for under a grand.Rocky
Chrysler Firepower
[Re: StealthWedge67]
#537410
11/27/09 06:12 PM
11/27/09 06:12 PM
Posts: 9,336 South-Central (Sebring), FL
Commando1
Unfortunately, 440-source is currently backordered on stealth heads. Ive had an order in with them for a couple of months now. They originally told me 4-6 weeks, but now They're saying mid December.
The container from China had a slight delay...
[Re: Commando1]
#537411
11/27/09 11:43 PM
11/27/09 11:43 PM
Posts: 5,948 British Columbia
chrisf
British Columbia
i am running a set on a 383 right now. i wouldnt buy another set, partially because of the quality issues but mostly the attitude i got when i emailed about the problem. my opinion is save your money and buy eddies, edelbrock stands behind their stuff. I stood up for Brandon here alot when he was bashed daily on quality and overseas sourcing issues, when it was my turn to experience those issues he blew me off. save your money, cheap will cost you more in the long run.
[Re: chrisf]
#537412
11/28/09 01:33 AM
11/28/09 01:33 AM
DaytonaTurbo
Manitoba, Canada
Oh so that's why eddys have a rep for taking them out of the box and straight to the machine shop for a couple hundred bucks worth of repair?
I don't know what problems you had with yours, however when I called about having bought a first production set which were said to have defective valve locks/retainers they gave me a new set without issue.
[Re: chrisf]
#537413
11/28/09 03:14 AM
11/28/09 03:14 AM
Posts: 58 Allentown,PA
68_300_conv
Allentown,PA
so what was the issue ?
[Re: 68_300_conv]
#537415
11/28/09 07:36 AM
11/28/09 07:36 AM
Posts: 1,949 land of 10,000______'s
BDS871Cuda
I think he had this problem.
Snap your neck, mega G-force launch, is all I want!
[Re: BDS871Cuda]
#537417
11/28/09 07:44 AM
11/28/09 07:44 AM
BDS871Cuda
But not this, this was someone else! This guy was making 1001 HP. He should of stayed under 1000!!! I don't know, just thinking what if I would of just took the other route. Anything can happen with any of this so called garbage. It works fine for one guy, and falls apart for the next guy. Example= Holley Blue fuel pump. some guys love em, others hate em.
[Re: 68_300_conv]
#537421
11/28/09 07:36 PM
11/28/09 07:36 PM
those heads look like they were run with the wrong antifreeze or the PH was way off on the mix. I have had a buddies set of heads off of his motor so we could slide a new 500 inch short block under them and there was no marking at all. Are those your heads or are you just saving the pictures so you can be part of the hater band wagon
your joking right? 5000miles NO WAY those heads should be looking like that. don't care if your running pure vinager. if you look closly at those head pics its obvious that thats a casting issue. quality control was bypassed that day. BTW what is the correct PH balance of antifreeze? all this time i thought it was either 70/30, 60/40, or 50/50 mix. now its PH balance... attached is a cylinder head with 80+k using the "wrong" antifreeze.
#537422
11/28/09 09:58 PM
11/28/09 09:58 PM
68_300_conv
Allentown,PA
http://www.eutechinst.com/techtips/tech-tips10.htm
[Re: 68_300_conv]
#537423
11/28/09 10:11 PM
11/28/09 10:11 PM
DaytonaTurbo
Manitoba, Canada
Interesting, but I never heard of someone checking ph before. Regardless, fresh coolant shouldn't go bad in 5000 miles.
