T&D Rocker set up on Indy EZ heads #536885
11/26/09 12:23 AM
11/26/09 12:23 AM
Central Coast
P
Plumcrazyracing Offline OP
P
Central Coast
Anyone have any experience with this set up? I am looking to upgrade the Indy valve train on my CNC'd EZ's. My spring pressures right now are around 235 on the seat and 485 open. Lift on cam is 621 in. ex.
Looking for pro's and con's, suggestions, and input from what combo's others have run besides the indy valve train on the EZ heads. Pictures a plus.
Thank you in advance!
Steve
Re: T&D Rocker set up on Indy EZ heads [Re: Plumcrazyracing] #536886
11/26/09 08:10 AM
11/26/09 08:10 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i have the T&D set up on my 325 cnc ez,s and have hade ZERO probs.it was all set up by dwayne at porter racing.ill have to look for my paper work if you need more info.or better yet just call and talk to Dwayne he,s a great guy and will give you the info you need to make a good decision.
Re: T&D Rocker set up on Indy EZ heads [Re: bonefish] #536887
11/26/09 10:40 AM
11/26/09 10:40 AM
NC
440Jim Offline
440Jim  Offline
NC
What part number T&Ds do you have?
Are these a single shaft system or individual shafts for each pair of rockers?
Re: T&D Rocker set up on Indy EZ heads [Re: 440Jim] #536888
11/26/09 10:52 AM
11/26/09 10:52 AM
Mopar Lane,Mississippi
67HEMI Offline
67HEMI  Offline
I have Harland Sharps 1.6's on my 295 ez heads with zero issues with .440 cam lift. They are not offset with the 295's. I think they were around 700.00 complete with shafts,spacers etc.
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction) '69 Chrysler 300 Convertible 375 HP 440 '71 Plymouth Duster 360 W/EFI (Wife's Ride) '12 Ram MegaCab Dually 6.7 Cummins
Re: T&D Rocker set up on Indy EZ heads [Re: 440Jim] #536889
11/26/09 06:00 PM
11/26/09 06:00 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
ill have to look for the info,but they are a single shaft.
Re: T&D Rocker set up on Indy EZ heads [Re: bonefish] #536890
11/26/09 06:06 PM
11/26/09 06:06 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We get our T&Ds through Indy.440-R4-4NB For the bigEZs and440-R4-4NBSR for the little EZs.
