Re: Headlight Switch Question
[Re: stumpy]
#536802
11/25/09 11:03 PM
11/25/09 11:03 PM
Posts: 1,719 Middle of the mitten
69DodgeCharger
Sounds like you could just clean the coil and the sweep on the switch you have to make it work.
Wire toothbrush, scotchbrite?
[Re: 69DodgeCharger]
#536803
11/25/09 11:14 PM
11/25/09 11:14 PM
Posts: 43,219 Bend,OR USA
Cab_Burge
Try some real fine crocus cloth, or 2000 grit wet and dry sandpaper You want to use it enough to burnish the corrosion off, not sand thru the contacts
#536805
11/26/09 04:30 PM
11/26/09 04:30 PM
Posts: 5,445 So Cal
Sinitro
So Cal
Another suggestion.. Jumper the dimmer rheostadt, its voltage drop is minimum so run the dash lites at a full 12V. They aren't that brite to begin with. Pull the 3 pin connector and jumper the 2 orange leads (I think at least the cars are orange) with a short lead and terminals. Just my $0.01..
