How much gain in new combo
#536641
11/25/09 06:36 PM
11/25/09 06:36 PM
Posts: 492 South Jersey, NJ
DragDart360
South Jersey, NJ
How much gain E/T MPH, I'd like to go very low 11's is it possible? Current .030 over 360, 9.0:1 comp 230@50 .480 lift cam, 915 heads uncut 2.02/1.60 valves, KB107 pistons, 1 5/8 headers, 3500 converter, best 11.75 @112 New Same 360 11.0:1 comp 253@50 .525 lift cam With ootb Eddy RPM heads? Ported? Better place to spend the money than the E heads? no other changes ![](http://i711.photobucket.com/albums/ww114/DragDart360/70Dart0103.jpg)
70 Dart Swinger, 2850 lbs SB 408, Bullet roller 264/268 @50 .636 SSDS stage 2 Edelbrock heads, 1 7/8 Headmans, 1050 dominator by Dom, 9.867 @ 133
Re: How much gain in new combo
[Re: forphorty]
#536644
11/27/09 07:45 PM
11/27/09 07:45 PM
DragDart360
South Jersey, NJ
I already have the cam it is a Comp 305H, How would it work with a single plane intake and the 4500 comverter. The iron heads were supposedly ported and have long valves. Shift at 6000? I really don't want to turn it more than that.
[Re: DragDart360]
#536645
11/27/09 11:39 PM
11/27/09 11:39 PM
Posts: 43,315 Bend,OR USA
Cab_Burge
[Re: Cab_Burge]
#536646
11/27/09 11:51 PM
11/27/09 11:51 PM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
Why do you want to limit the shift point to 6000 on a 360? Those things will go 7000 for years and years. What does your car weigh? My old Scamp years ago had a .030 over 340 in it with 11 to 1 compression, MP 557 solid cam and Eddy heads, and you're current extrememly mild 360 is already running the same numbers my 340 did. Mine liked a 5000 flash 8" converter and 4.30 gears with 28" tires. I trapped at 7000 with that motor.
[Re: ProSport]
#536647
11/28/09 10:21 PM
11/28/09 10:21 PM
DragDart360
South Jersey, NJ
I'll guess the car weighs about 2900 on the line. It has a cast crank and stock rods I'm afraid if I get too carried away I'll have a big pile of scrap metal. ![](/ubbthreads/images/graemlins/frown.gif) I'm saving for a better bottom end ![](/ubbthreads/images/graemlins/smile.gif)
