Re: Best way to remove butt stripe.
[Re: 6T9Hemi]
#536505
11/25/09 06:30 PM
11/25/09 06:30 PM
Posts: 4,861 Riverside, Ca
R70RUNNER
Riverside, Ca
Try a hair dryer first, or 3M sells a woodgrain and decal remover that works slick (spray can.) Melts the old decal off won't hurt the paint.
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
[Re: scratchnfotraction]
#536507
11/25/09 09:34 PM
11/25/09 09:34 PM
Posts: 3,407 S.E. Florida, USA
rrunner
S.E. Florida, USA
change shorts I was gonna say, start with butt wipe. But really there is a decal removing tool and disc/wheel. I have seen just the wheel to mount on a drill. We remove our logo's at work with one and if used correctly they will not harm the paint.
#536508
11/25/09 11:31 PM
11/25/09 11:31 PM
R70RUNNER
Riverside, Ca
change shorts
I used the 3m spray stuff to remove the decals from car lots
Ok, I was trying for ONCE...just once.. to take the high road! and see what happens? it reverts back to jokes...
[Re: 6T9Hemi]
#536509
11/26/09 11:05 AM
11/26/09 11:05 AM
Posts: 5,270 Missouri
MY340
Missouri
Heat lamp(just to warm up the panel) and hot air dryer may work well and it might peel right off. Otherwise you may need the 3M stripe eraser wheel if the stripe is real old. It works great but just use very light pressure and go slow. It will take it right off. I had to use both methods to get the fender stripes off my Duster to replace them.
1970 FE5 Duster 360/904/3.91's SOLD
1973 TB3 SpaceDuster 340/4spd/4.10's SOLD
Moparless for now but when the opportunity is right I'll have another one.
#536511
11/27/09 09:00 AM
11/27/09 09:00 AM
Posts: 4,852 KENTUCKY
69CHARGERMD
KENTUCKY
I just did this,,,,it was a bit of a pain in the .... I took the stripe off the back of the Charger,,,(white),,and changed it to matte black,,,very happy with the results,,,but it was some work getting the old stripe off. I ended up using a hair dryer,,,and peeling it back/off by hand,,,it came off in small sections,,,at time in small pieces,,,i was fortunate and did not ruin the paint,,,, I didnt use any solvents to get it off,,, I was going to use the 3M wheel but didnt want to burn thru,,,and since the stripe was so big,,,i wasnt sure it would work..... (there are probably easier ways to remove it than how i did it,,,i just took my time and got it off with the hair dryer and manual labor,,lol)
[Re: 6T9Hemi]
#536513
11/27/09 10:44 AM
11/27/09 10:44 AM
Posts: 3,719 Space Station #5
471Magnum
Space Station #5
If it's quite old, the stripe eraser is probably your best bet. The stripe material get pretty brittle overtime, and once it does, you can forget about peeling it off. A heat gun will soften the adhesive, but the vinyl just won't hold together.
Depending on the color of your car, and the paint quality, don't be surprised to find that the paint under the stripe no longer matches the rest of the car.
-Jim
I can fix it... my old man is a television repairman. He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
[Re: 471Magnum]
#536514
11/27/09 10:49 AM
11/27/09 10:49 AM
69CHARGERMD
KENTUCKY
The other issue was all the adhesive under the stripe once removed..... I used "goo-b-gone",,,,got it at autozone,,comes in a little bottle,,1-2 oz size,,,,, wiped it on and let it sit a few minutes,,,and it removed the underlying adhesive without any issues,,and no damage to the paint... My prior stripe had been on the car for at least 12 years,,,,the paint underneath looked fine and matched well...but the car doesnt sit in the sun much.... good luck. you might want to try the stripe remover wheel...if it works it might be quicker,,,,,i was just nervous about burning my paint with such a big stripe....
[Re: 69CHARGERMD]
#536515
11/28/09 12:20 PM
11/28/09 12:20 PM
MY340
Missouri
Gasoline & probably kerosene take the adhesive goo off too after stripe is removed.
