4" cowl hood for Duster #536210
11/25/09 02:50 AM
11/25/09 02:50 AM
Keysville, VA
drag440 Offline OP
mopar addict
drag440  Offline OP
mopar addict
Keysville, VA
Does anybody make a 4" cowl hood for a Duster that bolts on?
Re: 4" cowl hood for Duster [Re: drag440] #536211
11/25/09 07:40 AM
11/25/09 07:40 AM
Elbridge, NY
Dart1031 Offline
Dart1031  Offline
Elbridge, NY
AAR Fiberglass
Re: 4" cowl hood for Duster [Re: Dart1031] #536212
11/25/09 08:25 AM
11/25/09 08:25 AM
an8sec70cuda Offline
Glasstek. CHIP
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 4" cowl hood for Duster [Re: an8sec70cuda] #536213
11/25/09 11:08 AM
11/25/09 11:08 AM
Staten Island N.Y.
Dap Offline
Dap  Offline
Staten Island N.Y.
AAR or Glasstek as has been mentioned. Attached is a pic of mine from AAR but it is a pin on.
PRH446
10.084 @ 135.21 mph N/A through chambered mufflers,3300lbs. Stock stroke wedge
Re: 4" cowl hood for Duster [Re: Dap] #536214
11/25/09 12:05 PM
11/25/09 12:05 PM
Keysville, VA
drag440 Offline OP
mopar addict
drag440  Offline OP
mopar addict
Keysville, VA
I went to VFN, Glasstek and ARR's web site before I did this post and did not see them. Will they make it if you call them? I would like to go with AAR, but I only see them in pin on. This is going to be a street car and I want it to bolt on.
Re: 4" cowl hood for Duster [Re: drag440] #536215
11/25/09 12:17 PM
11/25/09 12:17 PM
SW Ohio
AAR-B4 Offline
AAR-B4  Offline
SW Ohio
The best result may be buying a flat hood and choosing the cowl scoop you want. Bond it on yourself or a body shop can do it pretty quickly. This way it can be located and fit on the car.
If you do it yourself cut the flange off the bottom of the scoop then trim it so it fits the contour of the hood before bonding.
Re: 4" cowl hood for Duster [Re: AAR-B4] #536216
11/25/09 12:41 PM
11/25/09 12:41 PM
Keysville, VA
drag440 Offline OP
mopar addict
drag440  Offline OP
mopar addict
Keysville, VA
I have a bolt on VFN hood on my Challenger now that I got them to custom make for me with a 5" tall six pac scoop, but I PAID for it.
Re: 4" cowl hood for Duster [Re: drag440] #536217
11/25/09 02:38 PM
11/25/09 02:38 PM
Cleveland Ohio
Discoquik Offline
Discoquik  Offline
Cleveland Ohio
Only thing about Glasstek is.....they actually fit.LOL Bought 3 hoods for this application from them. Half dollar round worth of filler in each hood. Urethane prime sand and spray. VERY good quality.
