On top of my 416 stroker.
Thermoquad w/LD340 or a Holley 750HP double pumper on an RPM Air-Gap?
95% street driven with 3.23 gears and a 2800 stall.
Comp solid roller 248/256
dur@.050 576/582" lift
Edelbrock heads.
11.5 to 1 comp.(yes, it works in Denver)
I'd kinda like to give the ole' Bakelite Wonder a chance on this motor but I think the holley is ideal for this setup. My thermoquad is the original that the car was born with(1973 #6139). I also have the Holley 750HP and the other two intakes. I just can't decide which way to go.
How much do you think I lose with the LD340 instead of the Air-Gap RPM?
I don't know why I'm having so much trouble with this....
Benny
