Will a 1941 front clip work on a 1940? #536136
11/24/09 11:27 PM
11/24/09 11:27 PM
dusterguy Offline OP
I am curious if a 41 hood, fenders, and bracketry work on my 40 P10? I like the look so much better.
Re: Will a 1941 front clip work on a 1940? [Re: dusterguy] #536137
11/26/09 08:36 AM
11/26/09 08:36 AM
moparx Offline
moparx  Offline
i would be willing to say the 41 clip would work, however, you would probably need to use everything and not be afraid to do some slight modifying of things such as brackets or retainers.not sure if the hood hinges are the same, but my hollander shows the 40 p9 and the p10 hoods as being the same for both coupe and sedan models. good luck on your project .
